September 22, 2014, 12:28 |
Incompressible Navier Stokes Test Case
Suman Chakraborty
Rep Power: 12 |
Hi there,
I was running the incompressible Navier Stokes test case of "Flow over a cylinder". I used a Reynolds Number of 200. I did an unsteady analysis using dual time stepping of 1st order. No Turbulent solver. I ran it in parallel using the python script on 6 cores. It generated output files but the program execution ended with an error message. Am attaching a snapshot of the error message. Kindly look into this and give a solution. Thank you. |
September 23, 2014, 01:44 |
Suman Chakraborty
Rep Power: 12 |
Hi there,
P { margin-bottom: 0.21cm; } Am facing another problem with the same test case , but now am using a Turbulent solver - SA turbulent model. Its displaying an error message that "Convective Scheme not implemented". I have tried with ROE solver. Looking into the Numerical Preprocessing in definition_structure.cpp - it shows that for incompressible euler or NS it has the option of ROE_1st and 2nd. Am attaching a snapshot of the error with this message. Please look into this and suggest where am I going wrong. Thank you. |
October 20, 2014, 15:48 |
#3 | |
Heather Kline
Rep Power: 14 |
The quick fix is to use ROE-1ST_ORDER The longer fix is to update your code to version 3.2.2 |
October 20, 2014, 16:38 |
Suman Chakraborty
Rep Power: 12 |
Thanks a lot for the reply
Error when run test case turb_ONERAM | mistuning | SU2 | 1 | October 3, 2013 02:17 |
matlab code of marker and cell method for solving 2d incompressible navier stokes eqn | sgangarapu | Main CFD Forum | 1 | August 28, 2013 11:33 |
High-order finite difference scheme for incompressible Navier Stokes equation | novan tofany | Main CFD Forum | 2 | April 5, 2012 07:34 |
Exact unsteady Stokes test case | neazen | Main CFD Forum | 5 | April 13, 2009 15:15 |
Incompressible Navier stokes with source term | mayur | FLUENT | 0 | August 6, 2004 07:07 |
