Home > Forums > Software User Forums > SU2
Triangular grids for RANS
Old   September 18, 2014, 03:58
Default Triangular grids for RANS
Aldo Bonfiglioli
abonfi is on a distinguished road
I have tried to run TestCasesv3.2.0/rans/naca0012 using triangular grids, rather than quadrilateral ones.
The triangular grids have been obtained by cutting into triangles the structured meshes available on the NASA website.
The three coarsest meshes are available here: https://dl.dropboxusercontent.com/u/60787983/meshes.zip
Using the same configuration file (except for the names given to the boundary patches) that runs successfully with the quad mesh, SU2 3.2 generates NaNs after a few non-linear iterations.
Aldo
abonfi is offline   Reply With Quote
Old   September 21, 2014, 22:36
Francisco Palacios
fpalacios is on a distinguished road
Interesting question... I think you should play with the value of the limiter a small value ~0.01 could be a good idea. And, obviously, reduce the CFL and disconnect the MG.
This is a good question, we will probably chat about this in our next YouTube video.
Cheers,
Francisco
fpalacios is offline   Reply With Quote
Old   September 23, 2014, 10:07
Facundo
akun646 is on a distinguished road
I have tried to run the triangular mesh (the medium one from the website), with both the VENKATAKRISHNAN and BARTH_JESPERSEN limiters. It did work, but the best residual I've got was only about 10E-3 and the results are still quite different from those of the quad mesh. So, still an open question!!
Cheers!!!
Facundo
akun646 is offline   Reply With Quote
Old   September 26, 2014, 21:49
Francisco Palacios
Please find in this link the reply to this post.
"This week in SU2": Wednesdays at 10:00am (PDT) on YouTube.
Best,
The SU2 team
Old   October 8, 2014, 07:27
Default Triangles or quads?
Aldo Bonfiglioli
Thank you for the video reply to my post.
Here
https://dl.dropboxusercontent.com/u/...3/naca0012.pdf
you can find a short document that reports numerical experiments with
the http://turbmodels.larc.nasa.gov/naca0012_val.html testcase, at 10 degrees AOA.
Figs. 5.7, 5.8 and 5.8 show comparisons between my own code, SU2 and the CFL3D data available on the NASA website.
Please note that the quad grids available in ver. 3.2.0 of the SU2 testcases have not been labelled correctly:
mesh_NACA0012_turb_897x257.su2 has NELEM=57344, so it has been derived from the 449x129 structured mesh, not the finest one.
I agree that as long as you can generate a quadrilateral boundary layer mesh,
that is probably preferable than using a triangular one.
I am not using unstructured FV schemes, but Residual Distribution (or Fluctuation Splitting, similar
to SUPG-FEM on iso P1 elements) ones, which require simplicial elements (triangles and tets).
Concerning testing SU2 on triangular boundary layer meshes: I am now using the
grid (and testcase) shown in Fig. 5.10(a) of the aforementioned document.
It has a "nice" triangular boundary layer mesh and is truly unstructured elsewhere.
Re-starting the 2nd order limited calculation from the 1st order one (as you suggested) is ok,
but iterative convergence of the 2nd order calculation remains problematic.
Regards,
Aldo
Does the grids topology matters? Anna Tian Main CFD Forum 11 August 19, 2014 03:20
[ICEM] Refine All Mesh problem with hexahedral grids FSVH ANSYS Meshing & Geometry 1 August 13, 2014 17:36
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 13:11
A question about dynamic overset grids JXIA Main CFD Forum 4 January 10, 2008 04:50
triangular grid or quadrilateral grid ravi Main CFD Forum 16 July 10, 2005 22:06
