Sirius
Rep Power: 12 ![]() |
I am trying to submit a SU2 parallel MPI run using the job scheduler PBS Pro. I get the following error
libibverbs: Warning: RLIMIT_MEMLOCK is 32768 bytes. This will severely limit memory registrations. -------------------------------------------------------------------------- The OpenFabrics (openib) BTL failed to initialize while trying to allocate some locked memory. This typically can indicate that the memlock limits are set too low. For most HPC installations, the memlock limits should be set to "unlimited". I don't get this error for other codes requiring large memory. Also if I run SU2 with MPI directly (i.e. without PBS), I don't face this problem. I am already setting ulimit to unlimited. If anybody has faced a similar issue and/or has a solution, please let me know. Thanks. |
Francisco Palacios
Rep Power: 15 ![]() |
Interesting problem, what case are your running? Have you tried with a really small simulation (e.g. quick start tutorial).
Best, Francisco |
mpi, pbs, rlimit_memlock, su2 |
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel | U.Golling | OpenFOAM Running, Solving & CFD | 52 | September 23, 2023 03:35 |
Initial conditions for uniform flow | andreas | OpenFOAM | 5 | November 16, 2012 15:00 |
[OpenFOAM] ParaView/Parafoam error when making animation | Disco_Caine | ParaView | 6 | September 28, 2010 09:54 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
