Home > Forums > Software User Forums > SU2
S duct NPARC validation case study
Old   September 8, 2014, 01:56
Default S duct NPARC validation case study
vetriselvan
vetri is on a distinguished road
Dear all,
I am trying to validate SU2 v 3.0 with NPARC S duct validation case. The results seems to be incorrect. I have attached the results, configuration file and the out file. Please let me know if something has to be changed. Your help will be highly appreciated. Thanks in advance.
Regards,
Vetri
vetri is offline   Reply With Quote
Old   September 9, 2014, 02:03
Francisco Palacios
fpalacios is on a distinguished road
Originally Posted by vetri View Post
Dear all,
Regards,
Vetri
The solution has not converged... could you please try with roe + limiter, CFL =~5 and the latest version of SU2 v3.2.1
Please keep in mind that the initial condition is computed using the Mach and the Reynolds number (Freestream values) and it should be related with the inflow outflow conditions otherwise the simulation will not work.
Best,
Francisco
fpalacios is offline   Reply With Quote
Old   September 12, 2014, 01:37
Default Thanks it worked :)
vetriselvan
Originally Posted by fpalacios View Post
Best,
Francisco
Dear Francisco Palacios,
I used SU2 v 3.2.1 and increased the CFL number without any other changes. The solution has converged. Thank you very much.
Regards,
Vetri
Duct case setup - Fan simulation nkjsimulating Main CFD Forum 0 October 10, 2013 05:15
solving a case on flow through duct hariya03 OpenFOAM Running, Solving & CFD 0 August 10, 2013 17:30
Validation case for fluid/solid interaction Raj Main CFD Forum 0 July 11, 2003 16:39
To verify case study ruengsak panyasen Main CFD Forum 1 July 15, 2001 16:44
Heat Transfer Validation test case Chris Whitney Main CFD Forum 1 July 21, 1999 15:36
