Home > Forums > Software User Forums > SU2
CGNS to .su2 mesh (multi zone, pointwise assistance?)
Old   August 29, 2014, 10:03
Default CGNS to .su2 mesh (multi zone, pointwise assistance?)
jacobH is on a distinguished road
I am interested in running some meshes with SU2 that are provided in CGNS format. However these contains multiple zones and therefore the SU2 CGNS reader doesn't support these. I was wondering if anyone would be so kind to assists me in converting these? I believe this should be possible by importing into Pointwise and then exporting via the SU2 plugin to the native .su2 format? I do not have a Pointwise license myself, so maybe there is a kind soul out there with a Pointwise lisence that would help me in converting these into the .su2 format?
The files I am interested in is located here: http://aero-comlab.stanford.edu/vdweide/CGNSFiles/
Many thanks for any help! Very much appreciated.
jacobH is offline   Reply With Quote
Old   September 7, 2014, 21:31
hlk
Heather Kline
hlk is on a distinguished road
Since the meshes are in CGNS format it might be possible to load them into an open-source meshing tool and convert to single-block CGNS from there. (Once it is a single block su2 should be able to load and convert the mesh)
hlk is offline   Reply With Quote
Old   September 8, 2014, 05:37
Thanks, do you have any suggestions for open source meshing tools?
Old   September 9, 2014, 02:12
Francisco Palacios
fpalacios is on a distinguished road
Maybe http://geuz.org/gmsh/ or http://www.larosterna.com/index.html . They also provide SU2 output format.
Cheers,
Francisco
fpalacios is offline   Reply With Quote
Old   September 9, 2014, 05:40
Thanks Francisco, I will have a look!
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 12:14
Journal file error magicalmarshmallow FLUENT 3 April 4, 2014 13:25
[GAMBIT] periodic faces not matching Aadhavan ANSYS Meshing & Geometry 6 August 31, 2013 12:25
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 11:52
[Other] 2D hex mesh on multi element airfoil Verfblikje OpenFOAM Meshing & Mesh Conversion 0 January 19, 2012 11:55
