Home > Forums > Software User Forums > SU2
SU2 Mesh Adaptation Using Adjoint and Gradient-based Methods
Old   August 28, 2014, 06:43
Default SU2 Mesh Adaptation Using Adjoint and Gradient-based Methods
Ashkaari
Ashkaari is on a distinguished road
Hello everyone. I'm trying to use SU2 on mesh adaptation for laminar flows. However I find no tutorial of it. After the flow equations and adjoint equations solved by SU2_CFD (cfg and mesh files for inv naca0012 are applied ), I run the command: SU2_MSH inv_NACA0012.cfg. After the routine ends, I open mesh_out.su2. Then i found there's no change in nelem(number of element?), so I wonder if the mesh has been adapted or not. It's very likely that I am doing it in the wrong way. Could someone tell me how to do it right? Much appreciated.
Ashkaari is offline   Reply With Quote
adjoint solver, mesh adaption, su2
SU2 AOA optimization 454514566@qq.com SU2 9 March 7, 2022 17:17
Gradient Computation: finite differences and adjoint method doan.nak SU2 3 November 22, 2017 06:37
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 06:18
best setting for SU2 mechy SU2 3 April 20, 2014 20:13
Inaccurate gradient results from continuous Adjoint method Yminjo SU2 1 January 11, 2014 23:08
