Home > Forums > Software User Forums > SU2
Unsteady Periodic Boundary Condition
Old   July 24, 2014, 17:16
Default Unsteady Periodic Boundary Condition
Eduardo Molina
EMolina is on a distinguished road
Hi Su2 users and developers.
I am having problems in setting periodic boundary conditions. I am trying to simulate 3D circular cylinder using URANS and DES (please see the other topic of Hybrid RANS/LES) with periodic boundary conditions in the spanwise direction.
I started with a 2D mesh and extrude this grid inside ICEM-CFD, so the nodes perfectly match in spanwise and export it in CGNS format. When I configure this 2 BC in spanwise using symmetry BC the code runs smoothly, but when I configure with periodic BC I have some non-physical points and the code diverges.
I tried to run SU2_PBC first, making the following change on cfg file:
MARKER_PERIODIC= ( SYM1, SYM2, 0.0, 0.0, 2.0, 0.0, 0.0, 0.0, 0.0, 0.0, 4.0, SYM2, SYM1, 0.0, 0.0, 2.0, 0.0, 0.0, 0.0, 0.0, 0.0, -4.0 )
%MARKER_SYM= (SYM1, SYM2)
The console output is:
-------------------- Setting the periodic boundaries --------------------
Setting the periodic boundary conditions.
Checking SYM2 boundary against periodic donor, SYM1.
Checking SYM1 boundary against periodic donor, SYM2.
Number of new points: 30584.
Number of new interior elements: 30252.
Number of new boundary elements added to preexisting markers: 664.
Segmentation fault
Note that SYM1 BC is located at Z=0.0 and SYM2 BC is located at Z=4.0.
SU2 can run with unsteady periodic BC or I am doing something wrong?
I appreciate any tips/help from the community, I also can attach a link to the 3D mesh and cfg file.
Regards.
Eduardo
EMolina is offline   Reply With Quote
Pressure boundary condition for unsteady velocity inlet DanM OpenFOAM Running, Solving & CFD 6 July 5, 2015 10:21
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
Bug in fvc::grad() and periodic boundary condition JBUNSW OpenFOAM 3 November 15, 2012 04:09
problem about periodic boundary condition in Fluent winnawinna FLUENT 0 December 29, 2010 00:32
Periodic boundary condition & Unsteady flow Somchai FLUENT 2 March 28, 2006 09:51
