Home > Forums > Software User Forums > SU2
Keywords applicable to various grid movement options
Old   July 23, 2014, 07:22
Default Keywords applicable to various grid movement options
Pranav Gujar
pranav is on a distinguished road
Hi
I need to simulate oscillatory motion of 2D flap. For this purpose I need to move only a part of aerofoil section. I have referred to the pitching NACA64010 test cases where the oscillatory motion of entire aerofoil is simulated using rigid motion option. However, it does not allow for specifying only select boundary markers for movement. I would like to know if this can be achieved in SU2?
I have also been through the config_template.cfg file to find out various grid movement options. However, it is not clear from the file which keywords are applicable for a particular grid movement type.
Can anyone guide me about which document I should refer to find out the keywords applicable for each of the following grid movement types?
1. RIGID_MOTION
2. DEFORMING
3. ROTATING_FRAME
4. MOVING_WALL
5. FLUID_STRUCTURE
6. AEROELASTIC
7. ELASTICITY
8. EXTERNAL
9. AEROELASTIC_RIGID_MOTION
Thanks!
pranav is offline   Reply With Quote
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 12:18
Algebraic Multigrid for nonuniform grid Joshua Lee Main CFD Forum 4 March 16, 2000 14:05
Non-uniform grid calculation Aspens Main CFD Forum 1 February 23, 2000 15:15
Grid Quality and the Solution Faraz Main CFD Forum 4 January 10, 2000 19:18
Numerical methods for discontinuous grid interfaces? Hansong Hang Main CFD Forum 12 September 16, 1998 23:26
