Home > Forums > Software User Forums > SU2
Is degenration a problem?
Old   July 21, 2014, 02:29
Default Is degenration a problem?
nilesh
nilesh is on a distinguished road
I am creating a 3D mesh using hexahedral elements. In some regions, the hexahedrals are supposed to actually convert into wedges due to overlapping of their sides and some rectangles will consequently get converted to triangles at the boundary surfaces (imagine meshing a cylinder with hexahedrals).
Instead of defining wedge elements seperately, if I declare these elements as hexahedrals with two pairs of distinct nodes having the same coordintes so that geometrically it is actually a wedge, will it cause any error in flow computation?
Similar is the case of defining a rectangle with one repeated coordinate.
Thanks.
nilesh is offline   Reply With Quote
Old   July 21, 2014, 16:00
Francisco Palacios
fpalacios is on a distinguished road
Originally Posted by nilesh View Post
Thanks.
In principle, it should work. In the past we have found some issues with the gradient computation… our recommendation is to use Green Gauss.
Cheers,
Francisco
fpalacios is offline   Reply With Quote
Old   July 22, 2014, 01:05
nilesh
Originally Posted by fpalacios View Post
Cheers,
Francisco
Thank you Sir. Can you please point to a source/paper which talks about the effect of cell degeneration in finite volume computation?
3d grid, hexahedral, su2, wedge
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
