Home > Forums > Software User Forums > SU2
SU2 v3.1.0 parallel error
Old   July 10, 2014, 08:53
Default SU2 v3.1.0 parallel error
Tony Xuan
Tonyshaoyu is on a distinguished road
Every time I try running the script parallel_computation.py, an error pops up which says "No module named 'interface' "...
There are actually several modules in the same directory, but the other modules are imported normally except this one...
Anybody has encounter the same error?
Looking forward to any helpful reply...
Tonyshaoyu is offline   Reply With Quote
Old   July 19, 2014, 14:24
Francisco Palacios
fpalacios is on a distinguished road
parallel_computation.py is not a critical script. You can always run the codes sequentially:
$mpirun SU2_PRT -n 4 -f default.cfg
$mpirun SU2_CFD -n 4 -f default.cfg
$mpirun SU2_SOL -n 4 -f default.cfg
Cheers,
Francisco
fpalacios is offline   Reply With Quote
parallel computation, python module
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 08:11
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
