July 2, 2014, 08:13 |
please help with the following error
Amit
Rep Power: 12 |
i am a new user for SU2, a novice too.
i get the following error on running a .cfg file in parallel Traceback (most recent call last): File "/opt/SU2/bin/parallel_computation.py", line 111, in <module> main() File "/opt/SU2/bin/parallel_computation.py", line 56, in main options.divide_grid ) File "/opt/SU2/bin/parallel_computation.py", line 71, in parallel_computation config = SU2.io.Config(filename) File "/opt/SU2/bin/SU2/io/config.py", line 91, in __init__ raise IOError , 'Could not find config file: %s' % filename IOError: Could not find config file: channel.cfg amit@amit-Z580:~/Desktop/chanl10*10$ this maybe a basic doubt,but still help me with it. thanks in advance |
July 2, 2014, 15:31 |
Brendan Tracey
Rep Power: 13 |
What did you call from the command line? It looks like you aren't supplying a config file
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 01:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 10:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 10:17 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
