March 31, 2014, 22:19 |
Running Oneram6 in parallel issues
Carlos Alexandre Tomigawa Aguni
Rep Power: 12 |
Hello guys.
I've ran Oneram6 in serial successfully. Now I'm facing some issues trying to run it in parallel. What should I do in order to paralellize SU2's 2nd Tutorial? What's parallel_computation.py actually doing? I'm running on a cluster that has 6 nodes that has 2 Xeons each. I've ran this tests: Code:
/opt/su2/bin/parallel_computation.py -f inv_ONERAM6.cfg -p 12 /opt/su2mpich2/bin/parallel_computation.py -f inv_ONERAM6.cfg -p 12 MPICH 3.1 Intel MPI 4.1 Icc/icpc 14.0.1 Code:
./configure --prefix="/opt/su2mpich2" --with-Metis-lib="/opt/metis1/lib" --with-Metis-include="/opt/metis1/include" --with-Metis-version=5 --with-MPI="/opt/mpich2/bin/mpicxx" Code:
./configure --prefix="/opt/su2" --with-Metis-lib="/opt/metis1/lib" --with-Metis-include="/opt/metis1/include" --with-Metis-version=5 --with-MPI="/opt/intel/impi/4.1.3.048/intel64/bin/mpicxx" 41 53.693333 -6.208682 -5.711006 0.286449 0.011889 41 53.682143 -6.208682 -5.711006 0.286449 0.011889 41 53.572857 -6.208682 -5.711006 0.286449 0.011889 41 53.863571 -6.208682 -5.711006 0.286449 0.011889 41 53.754524 -6.208682 -5.711006 0.286449 0.011889 41 53.650000 -6.208682 -5.711006 0.286449 0.011889 41 53.890476 -6.208682 -5.711006 0.286449 0.011889 41 53.882857 -6.208682 -5.711006 0.286449 0.011889 41 53.901667 -6.208682 -5.711006 0.286449 0.011889 41 53.967381 -6.208682 -5.711006 0.286449 0.011889 41 53.824048 -6.208682 -5.711006 0.286449 0.011889 42 53.672791 -6.255845 -5.757245 0.286496 0.011876 42 53.678605 -6.255845 -5.757245 0.286496 0.011876 42 53.692791 -6.255845 -5.757245 0.286496 0.011876 42 53.572093 -6.255845 -5.757245 0.286496 0.011876 42 53.856279 -6.255845 -5.757245 0.286496 0.011876 42 53.745814 -6.255845 -5.757245 0.286496 0.011876 42 53.651628 -6.255845 -5.757245 0.286496 0.011876 42 53.879767 -6.255845 -5.757245 0.286496 0.011876 42 53.877209 -6.255845 -5.757245 0.286496 0.011876 42 53.894419 -6.255845 -5.757245 0.286496 0.011876 42 53.961628 -6.255845 -5.757245 0.286496 0.011876 42 53.823721 -6.255845 -5.757245 0.286496 0.011876 43 53.672955 -6.302153 -5.803464 0.286533 0.011862 43 53.675909 -6.302153 -5.803464 0.286533 0.011862 43 53.692273 -6.302153 -5.803464 0.286533 0.011862 43 53.571818 -6.302153 -5.803464 0.286533 0.011862 43 53.737727 -6.302153 -5.803464 0.286533 0.011862 43 53.847955 -6.302153 -5.803464 0.286533 0.011862 43 53.652500 -6.302153 -5.803464 0.286533 0.011862 43 53.876136 -6.302153 -5.803464 0.286533 0.011862 43 53.886364 -6.302153 -5.803464 0.286533 0.011862 43 53.876818 -6.302153 -5.803464 0.286533 0.011862 43 53.957045 -6.302153 -5.803464 0.286533 0.011862 43 53.822045 -6.302153 -5.803464 0.286533 0.011862 Note that each iteration is printed 12 times.. The same goes for any number inserted in p. Note : I'm using MPI + Metis. Not CGNS. thanks in advance! Last edited by CrashLaker; April 4, 2014 at 16:28. |
April 4, 2014, 16:17 |
Heather Kline
Rep Power: 14 |
I have gotten this type of behavior when SU2 was not compiled with parallel tools. Go back to your configuration and check to make sure that the paths to the appropriate libraries are correct, and look through the config output to make sure that SU2 is being compiled with mpi.
April 4, 2014, 16:35 |
#3 | |
Rep Power: 12 |
Do you strongly think this is a problem with MPI over anything else?.. |
April 4, 2014, 16:50 |
Heather Kline
Rep Power: 14 |
when you say that the configure script says it has MPI support, I assume you mean that there is a line in config.log like:
MPI support: yes I see that you also commented on http://www.cfd-online.com/Forums/su2...ify-nodes.html Since you are running on a cluster, as mentioned in the post linked above, you should also look into the cluster-specific requirements. Unfortunately, that is beyond my expertise, and you will need to talk to the cluster administrator or another user familiar with the specifics of your cluster. |
April 4, 2014, 17:27 |
Santiago Padron
Rep Power: 13 |
Your original post had said that you compiled without Metis. Metis is needed to run a parallel computation, that is probably why you are seeing the repeated output. I would recommend you make clean and then compile again with Metis support.
As for your question of "What's parallel_computation.py actually doing?" The parallel_comutation.py script automatically handles the domain decomposition with SU2_DDC, execution of SU2_CFD, and the merging of the decomposed files using SU2_SOL. This is described in more detail in Tutorial 6 - Turbulent ONERA M6. |
April 5, 2014, 06:14 |
Hexchain T.
Could you please explain how do you compile SU2 with Intel MPI? My try failed with several "mpi.h must be included before stdio.h" errors, and maunally #undef SEEK_* makes it fail later on some MPI functions. |
April 5, 2014, 13:39 |
Heather Kline
Rep Power: 14 |
The general directions for compiling with MPI and Metis can be found near the bottom of the following page:
http://adl-public.stanford.edu/docs/...on+from+Source |
April 5, 2014, 16:14 |
#8 | |
Rep Power: 12 |
Thanks for commenting about Turbulent Onera I'm going to check it out there for in depth details. What should happen after running SU2_DDC? Should it create new mesh files depending on the number of divisions specified? I'm asking that because after I run SU2_DDC it doesn't create anything. Do you think there's a problem there? Hexchain. I was able to compile with Intel MPI easily but I've read some threads in which you had to add mpi.h include in 3 files (It's a thread in this forum but now I don't know them exactly). |
SU2 parallel installation error | JAlbert | SU2 Installation | 2 | November 19, 2013 02:43 |
SU2 Parallel Computation | pdp.aero | SU2 Installation | 5 | June 19, 2013 14:02 |
[swak4Foam] Bug in groovyBC in parallel computation | Aleksey_R | OpenFOAM Community Contributions | 19 | September 18, 2012 07:50 |
Parallel computation using NUMECA 6.1 | BalanceChen | Fidelity CFD | 1 | June 5, 2011 06:24 |
UDF for parallel computation | Stanislav Kraev | FLUENT | 3 | October 10, 2006 03:12 |
