Home > Forums > Software User Forums > SU2
Question about testcase euler/oneram6
Old   March 31, 2014, 09:49
Default Question about testcase euler/oneram6
Becky
b614910 is on a distinguished road
I try to run the testcase euler/oneram6 given by the website.
I don't really understand why it terminated at iteration 100.
The convergence criteria it used is RESIDUAL.
According to Tutorial, it means that the simulation will terminate once the density residual reaches a value that is RESIDUAL_REDUCTION orders of magnitude smaller than its value at iteration STARTCONV_ITER
However, the simulation stopped exactly at STARTCONV_ITER (100).
The density residual didn't reach RESIDUAL_MINVAL either.
I am quite confused with it.....
The attachment is the configuration file I used and the information printed on screen when I ran the simulation.
Thanks for your help!
Becky
b614910 is offline   Reply With Quote
Old   April 3, 2014, 20:47
David Manosalvas-Kjono
demanosalvas is on a distinguished road
Becky,
The reason why your simulation is stopping is because the stopping criteria is either the reduction of 5 orders of magnitude or the residual reaching a -6 order. In your case the -6 order is reached before the 5 orders of magnitude reduction.
% Residual reduction (order of magnitude with respect to the initial value)
RESIDUAL_REDUCTION= 5
% Min value of the residual (log10 of the residual)
RESIDUAL_MINVAL= -6
David
demanosalvas is offline   Reply With Quote
Old   April 4, 2014, 11:53
Becky
David,
Thanks for your reply!
After decreasing the RESIDUAL_MINVAL value to a smaller one, the testcase finally follow the convergence criteria (stop at the reduction of 5 orders of magnitude).
However, when I increase the RESIDUAL_MINVAL value which is equal to or bigger than -6, the testcase always stopped at iter100 and the residual value was around -8, which is obviously smaller than -6. I just don't understand why it didin't stop immediately after reaching the RESIDUAL_MINVAL. :S
Becky
Old   April 6, 2014, 01:32
Becky,
This is because you are telling the code to start checking the convergence criteria at iteration 100 :
% Start convergence criteria at iteration number
STARTCONV_ITER= 100
If you want to check it much sooner, and stop as soon as it hits the criteria, try reducing the value in STARTCONV_ITER (the option shown above) to 10.
Hope this helps,
David
Old   April 6, 2014, 08:29
Becky
David,
I understand how it works now.
Thanks for your replies they help me a lot! (:
Becky
small question about the functionalities of topological changes in OpenFoam ngj OpenFOAM Running, Solving & CFD 2 February 28, 2013 11:02
Question Re Engineering Data Source imnull ANSYS 0 March 5, 2012 14:51
internal field question - PitzDaily Case atareen64 OpenFOAM Running, Solving & CFD 2 January 26, 2011 16:26
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 05:37
Philosophical CFD question Richard Howe Main CFD Forum 14 June 17, 2001 15:41
