Home > Forums > Software User Forums > SU2
Tutorial 2 - Parallel run
Old   March 20, 2014, 22:47
Default Tutorial 2 - Parallel run
Nicholas Yue
nicholas_yue is on a distinguished road
I have successfully run tutorial 2 (using the test case data I downloaded)
http://adl-public.stanford.edu/docs/...iscid+ONERA+M6
in serial mode and looked at the results in Paraview.
When I continue the same tutorial to learn about the parallel execution, I found that the Python script parallel_computation.py makes assumption that the mesh is named "mesh.su2" rather than the mesh name specified in the configuration file.
To make it easier to continue, I elected to modify the name of the mesh file and the inv_ONERA6.cfg file instead of modifying the python script.
The next problem I encountered is more complicated. The generated file config_DDC.cfg did not contain the LOWER_SIDE definition expected by SU2_DDC
Is there any other tutorial/example (in 3D) which I can look at that is known to work via a parallel approach ?
Cheers
nicholas_yue is offline   Reply With Quote
Old   March 24, 2014, 21:33
Carlos Alexandre Tomigawa Aguni
CrashLaker is on a distinguished road
Imma give it a try and post here what I got.
CrashLaker is offline   Reply With Quote
Old   March 25, 2014, 13:53
hlk
Heather Kline
hlk is on a distinguished road
If the config file is being called correctly, the mesh used should be the one specified in the config file and not the default, so I suspect that there may have been a typo when typing the config file name. (this is an error that I have made myself multiple times) That would also explain why SU2_DDC is having trouble - if the main config file is not being read in, the default settings loaded by SU2_DDC will not match the mesh file.
To run the case in parallel on two processors, after making sure that you have configured SU2 to run in parallel, type the following command in your run directory:
>> parallel_computation.py -f inv_ONERAM6.cfg -p 2
hlk is offline   Reply With Quote
Dam Break Tutorial - 2.3.11 Running in parallel vitors OpenFOAM Running, Solving & CFD 3 August 2, 2019 20:22
Parallel run: boundary condition missing on processorX/0 lovecraft22 OpenFOAM Running, Solving & CFD 6 May 29, 2012 17:06
problem in parallel run in Workbench Mina_Shahi CFX 0 September 8, 2011 12:27
Parallel run in fluent for multiphase flow apurv FLUENT 2 August 3, 2011 20:44
First Parallel Run - need some help Gian Maria OpenFOAM 3 June 17, 2011 13:08
