Home > Forums > Software User Forums > SU2
Mesh with Prism Layers
Old   March 14, 2014, 08:14
Default Mesh with Prism Layers
Mohammed Gowhar
mdgowhar is on a distinguished road
Hi all,
I created a mesh for an airfoil NACA 63415 2-D case with prism layers. But latest SU2 version throws an error that unrecognized mesh. Hence i created the mesh again with tets only and ran it. The simulation is successfully running. What is the reason prism layers are not recognized in this latest version?
Cheers
Gowhar
mdgowhar is offline   Reply With Quote
Old   March 14, 2014, 12:00
vetriselvan
vetri is on a distinguished road
Hi Gowhar,
How you are generating the mesh ? Which mesh generator you use ?
Regards,
Vetri
vetri is offline   Reply With Quote
Old   March 19, 2014, 04:34
Mohammed Gowhar
Thanks for the response.
I am using Ansys mesher.
Cheers,
Gowhar
Old   March 20, 2014, 10:36
vetriselvan
I had problems with converting meshes generated from ICEM CFD to cgns file format which SU2 accepts. I have not used ansys mesher. Hope you are also converting your initial mesh to cgns and then trying to use it in SU2 and in that process having some trouble. If that is the case you can try suggestions in this thread
http://www.cfd-online.com/Forums/su2...nized-su2.html
Initially when my mesh had only tetra it ran without problems like your's but with prisms I had problems. Then I tried the above method in the thread and it worked.
Regards,
Vetri
incompressible flow, mesh 2d, prism layers
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 08:34
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 05:31
[ICEM] Can't create prism layer on 2D extruded mesh PedroC ANSYS Meshing & Geometry 19 April 19, 2011 21:48
