February 18, 2014, 09:02 |
fluid_structure not running
Yibin Dou
Rep Power: 16 |
hello
does anyone run the fluid_structure test case? how can it run? i use the following command su2_cfd fluid_structure_beam2D.cfg the error is "The configuration file doesn't have any definition for makder lower!!" in fluid_structure_beam2D.cfg, the boundary "lower" is defined in MARKER_LOAD= ( upper, -1E4, lower, 0.0, outlet, 0.0 ) what is the problem? |
February 19, 2014, 19:03 |
#2 | |
Francisco Palacios
Rep Power: 15 |
The fluid structure simulation capabilities are in place (flow solver + linear elasticity solver + grid motion + coupling), but not updated. The SU2 team is aware of the importance of this capability and we are working on this for the next release. Thanks for using SU2, Francisco |
March 19, 2015, 01:35 |
segmentation fault
varghese mathew
Rep Power: 12 |
wat does segmentation error (crore dumped ) means .i guess i gave some string value wrong .i corrected the previous error in reading the multi domian file it read all points nw .the problem was the npoin option the no were repeated twice .but hw to get past this error of segmentation in fsi case.i want to run a 3d flutter case thats all for a typical agard wing .if anyone has any idea let me know plzz
how to run the propeller Tutrial | immortality | OpenFOAM Running, Solving & CFD | 10 | February 22, 2014 09:33 |
Something weird encountered when running OpenFOAM in parallel on multiple nodes | xpqiu | OpenFOAM Running, Solving & CFD | 2 | May 2, 2013 04:59 |
What do you CFD guys do during a long simulation running? | bearcat | Main CFD Forum | 5 | July 23, 2009 08:08 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 07:52 |
star is not running the simulation in windows | Arnab | Siemens | 1 | August 2, 2004 02:40 |
