February 7, 2014, 11:38 |
Axisymmetric pipe flow example
Tim Gowing
Rep Power: 13 |
I am interested in running axisymmetric pipe flow problems including heat transfer.
Can anyone provide me with .cfg & .su2 files for a simple example to get started? Your help is much appreciated. Kind regards, Tim |
February 11, 2014, 03:16 |
Axisymmetric option name
Tim Gowing
Rep Power: 13 |
I haven't found the option to select an axisymmetric boundary condition. Can someone please direct me to the documentation for this? Kind regards, Tim |
February 12, 2014, 14:40 |
Rep Power: 14 |
Hi Tim,
You can perform an axisymmetric simulation by adding the following two lines to your config file: AXISYMMETRIC= YES SOUR_NUM_METHOD_FLOW= PIECEWISE_CONSTANT Hope this helps, Aniket |
February 12, 2014, 16:31 |
Tim Gowing
Rep Power: 13 |
Aniket,
February 15, 2016, 14:26 |
Anant Diwakar
Rep Power: 13 |
Can you share some testcases for axisymmetric flow in SU2 ? Anant |
February 16, 2016, 04:11 |
Mike
Rep Power: 10 |
Aniket,
I'm not sure the second option is correct in the latest versions (4.1), I tried it and got the following error. "SOUR_NUM_METHOD_FLOW: invalid option name. Check current SU2 options in config_template.cfg." I just use the first option and use a symmetry boundary condition for the axis. Even then I'm a little dubious of the result as it outputs positive values of lift whereas if the simulation was truly axisymmetric the lift should be equal to 0. M. |
February 20, 2016, 15:46 |
Ankita Humne
Hey Aniket,
I get the same error as Mike for "SOUR_NUM_METHOD_FLOW". However, the first option (AXISYMMETRIC = YES) works only for compressible for me and gives segmentation fault for incompressible. How can I fix this? Thanks, Ankita |
March 29, 2017, 04:27 |
2D - Axisymmetric case and non zerolift
I have the same doubt. There should not be any lift for axisymmetric case.
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry | mazhar1613 | ANSYS Meshing & Geometry | 1 | January 11, 2012 23:18 |
[ASK] Flow in Corrugated Pipe with FLUENT | Primadhani | FLUENT | 1 | May 11, 2011 20:41 |
Pipe Flow | Saima | CFX | 1 | January 10, 2011 16:41 |
Turbulence intensity in fully devloped pipe flow - Reference | Shocktrain | Main CFD Forum | 0 | October 14, 2010 06:58 |
Axisymmetric Flow | S. Kumar | Main CFD Forum | 0 | November 10, 2001 10:15 |
