Home > Forums > Software User Forums > SU2
Open Rotor TestCase problem
Old   January 24, 2014, 12:21
Default Open Rotor TestCase problem
mbaker is on a distinguished road
I am trying to run the open_rotor test case. Even though the input file has RESTART_SOL=NO, the code still crashes with the following error message. I am sure this is something very simple, and appreciate the help in advance.
------------------------- Solver Preprocessing --------------------------
Area projection in the z-plane = 0.0748494.
Initialize jacobian structure (Euler). MG level: 0.
There is no flow restart file!! solution_flow.dat.
mbaker is offline   Reply With Quote
Old   January 28, 2014, 16:36
Trent Lukaczyk
rktchip is on a distinguished road
you might have it set to MATH_PROBLEM=ADJOINT, in which case it would look for this file. Make sure MATH_PROBLEM=DIRECT
rktchip is offline   Reply With Quote
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 10:50
open channel problem (free surface) Andy Chen FLUENT 4 July 10, 2009 02:20
How did I set a discharge or depth curve at inflow boundary? (open channel problem) Andy Chen FLUENT 0 June 29, 2009 11:11
Problem in Installation of Open Foam Shishir OpenFOAM Installation 2 May 28, 2009 16:05
