Home > Forums > Software User Forums > SU2
Artificial viscosity introduction
Old   January 23, 2014, 11:43
Default Artificial viscosity introduction
Olivier Soucy
osoucy is on a distinguished road
I need to simulate the flow field around multi-blunt-body configurations. I'm only interested in flow velocities on a macro level since the solution will be interpolated on a coarser grid with cell sizes of about 5% of the characteristic length of each body.
Typically, I solved the flow field using the Euler equations which provided enough accuracy for my specific needs. However, would it be possible to introduce some level of flow separation and turbulence effects without solving the full Navier-Stokes equations with a turbulence model? Is it possible to artificially locally introduces some viscous effects?
Regards,
osoucy is offline   Reply With Quote
Old   January 28, 2014, 16:27
hlk
Heather Kline
hlk is on a distinguished road
One option to introduce viscosity without using a turbulence model would be to set the turbulence model to 'KIND_TURB_MODEL=NONE' and 'PHYSICAL_PROBLEM = RANS' in order to simulate viscous, laminar flow, but since you specifically mention turbulence and separation that may not be what you are looking for.
An alternative that would avoid the RANS simulation, which unfortunately as far as I know has not been implemented with SU2, is to use a coupled Euler boundary-layer approach.
An example of this method (using CART3D) is described in arc.aiaa.org/doi/pdf/10.2514/6.2006-652.
hlk is offline   Reply With Quote
Problem with divergence TDK FLUENT 13 December 14, 2018 07:00
Artificial Viscosity MAB CFX 1 July 30, 2008 23:00
Artificial viscosity rads CFX 2 July 31, 2006 08:02
artificial viscosity rvndr Main CFD Forum 1 March 2, 2004 11:24
Artificial Viscosity Girish Bhandari Main CFD Forum 5 January 13, 2001 14:22
