Home > Forums > Software User Forums > SU2
Viscous flow with euler boundary condition
Old   January 23, 2014, 11:30
Default Viscous flow with euler boundary condition
Olivier Soucy
osoucy is on a distinguished road
Suppose I need to solve for the flow field around two spheres that are about 2 to 5 diameters apart. I'm not interested in calculating accurate aerodynamic coefficients or pressure distributions. I only need a moderately accurate representation of the flow velocity on a macro level. The final flow field velocities will interpolated on a coarse grid (cell sizes of about 5% of the spheres diameters).
Also, I would only be interested in computing turbulence effects and flow separation near one of the sphere. Since, I'm trying to minimize computational cost, would it make sense to impose navier-stokes boundary condition on one sphere, to impose euler boundary condition on the other one and to solve the flow with a turbulence model? Would it even converge?
Any help would be appreciated.
Regards,
osoucy is offline   Reply With Quote
Old   May 12, 2015, 17:46
Juan J. Alonso
jjalonso is on a distinguished road
Hi there,
It depends on what you mean by "moderately accurate flow at the macro level". If you do not care about the wake of one of the cylinders, you could very well impose an inviscid boundary condition there and a viscous / no-slip on the other cylinder, thus saving he boundary-layer mesh on one of the cylinders. The calculation will run more quickly (and it should converge) but you will be missing some of the physics. Then again, if you do not care about the physics in that portion of the domain, things should be fine.
Best,
Juan
jjalonso is offline   Reply With Quote
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Mass flow rate boundary condition for continuity equation for oscillating flow p07ip705 Main CFD Forum 0 February 28, 2013 02:33
Airfoil boundary condition Frank Main CFD Forum 1 April 21, 2008 19:36
How can apply mass flow rate boundary condition? Sima Phoenics 1 December 1, 2007 19:55
Boundary Conditions Jan Ramboer Main CFD Forum 11 August 16, 1999 09:59
