Home > Forums > Software User Forums > SU2
Add GMSH output
Old   January 20, 2014, 20:34
Default Add GMSH output
cean wang
ceanwang is on a distinguished road
I started from su2_cfd\src\output_tecplot.cpp and changed
the COutput::SetTecplot_ASCII function.
Now it can outputs flow.pos and surface_flow.pos which are GMSH pos files and you could view them with GMSH.
Welcome to try from
here.
Enjoy
Cean
ceanwang is offline   Reply With Quote
Old   January 28, 2014, 16:15
Trent Lukaczyk
rktchip is on a distinguished road
great! it would be cool if you could submit a pull-request to the github repo -
https://github.com/su2code/SU2
then we can try incorporating it in future releases
rktchip is offline   Reply With Quote
checking for C++ compiler default output file name... configure: error: C++ compiler dhxlxz SU2 Installation 2 September 7, 2013 12:08
CGNS Output file parameters ant0wn SU2 1 August 19, 2013 15:47
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
running without a terminal output and saving time step information instead Sören Sander OpenFOAM Pre-Processing 2 November 30, 2012 10:03
[ANSYS Meshing] Question about ICEM mesh output to CFX lnk ANSYS Meshing & Geometry 0 July 27, 2012 16:39
