Cannot do the DEFORMING option for oscillating airfoil with SA model in Parallel |
Jianming Liu
Rep Power: 17 ![]() |
Dear,
I found the SU2 (including SU2v3.00) can not do the DEFORMING option for oscillating airfoil with SA model in Parallel. Is there anyone who has tested this computation in parallel. For the Tutorial 2 (Inviscid ONERA M6), it can be run in parallel. Hence the installation of the software is right. Thank u. Jianming Last edited by liujmljm; January 17, 2014 at 12:24. |
Jianming Liu
Dear,
I has tested my case in serial. But it spent much time to compute. So I want to calculate the case in parallel. The condition on this case is %Mach=0.2 %Re=3.45e6, SA model %mean aoa=0, delta aoa=20, reduce frequence k=0.1 The result is attached. In this case, I use SA model to do this simulation. I am not sure about the result. Is there someone who has some comments on the result. Thank u. Jianming Last edited by liujmljm; January 31, 2014 at 10:45. |
Jianming Liu
the parallel computation of the deforming option on the SA model can not work. Is there some people try this? thanks
Jianming |
Tommy Chen
Rep Power: 15 ![]() |
Jianming Liu
Traceback (most recent call last):
File "/home/james/SU2_v3p0/SU2/bin/parallel_computation.py", line 113, in <module> main() File "/home/james/SU2_v3p0/SU2/bin/parallel_computation.py", line 58, in main options.divide_grid ) File "/home/james/SU2_v3p0/SU2/bin/parallel_computation.py", line 73, in parallel_computation config = SU2.io.Config(filename) File "/home/james/SU2_v3p0/SU2/bin/SU2/io/config.py", line 88, in __init__ self.read(filename) File "/home/james/SU2_v3p0/SU2/bin/SU2/io/config.py", line 94, in read konfig = read_config(filename) File "/home/james/SU2_v3p0/SU2/bin/SU2/io/config.py", line 291, in read_config assert not data_dict.has_key(this_param) , ('Config file has multiple specifications of %s' % this_param ) AssertionError: Config file has multiple specifications of ADJ_OBJFUNC |
Jianming Liu
#7 | |
Tommy Chen
Due to the assertion error:Config file has multiple specifications of ADJ_OBJFUNC It seems that you have defined the term ADJ_OBJFUNC more than once. Could you post the configuration file you are using ? |
Jianming Liu
Error message: Insufficient Catalogue Size | Paresh Jain | CFX | 33 | August 16, 2024 05:09 |
ansys cfx solver exit with return code 1!!!!! | mhabibnia | CFX | 7 | August 19, 2013 03:53 |
How tensor parameters to be entered in CFX-pre? | hadi.iraji | CFX | 1 | May 7, 2013 04:03 |
CFX13 Post Periodic interface | EtaEta | CFX | 7 | December 8, 2011 17:15 |
transient simulation of a rotating rectangle | icesniffer | CFX | 1 | August 8, 2009 07:25 |
