Number of internal iterations in the Dual time method |
December 23, 2013, 09:52 |
Anant Diwakar
Rep Power: 13 |
Hi All
I am trying to run an unsteady simulation using Dual time stepping, over NACA0012 airfoil. I am using Euler Implicit time integration scheme. I wanted to know how to select the value of internal iterations UNST_INT_ITER, for the dual time method ? I ran the steady case which took around 40000 iterations for the given convergence criteria. Is the value of internal iterations for the dual time method related to this ? Thanks Anant |
January 11, 2014, 23:16 |
Francisco Palacios
Rep Power: 15 |
Instead os specifying the number of iteration you can specify the convergence level (3-4 order of magnitude would be OK)
RESIDUAL_REDUCTION= 3 In principle the inner iteration should converge quicker than the steady state case because the physical step is typically very small and your initial guess is close to the final solution after Deta t. Best Regards, Francisco |
Sudden jump in Courant number | NJG | OpenFOAM Running, Solving & CFD | 7 | May 15, 2014 14:52 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 14:58 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 10:34 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 04:34 |
Computational time | sunnysun | OpenFOAM Running, Solving & CFD | 5 | March 16, 2009 04:32 |
