Tool to convert OpenFoam mesh to SU2 mesh (2D and 3D) |
October 5, 2023, 01:07 |
Script Bug?
#41 |
Moshe Hollander
Rep Power: 8 |
Sorry to revive an old thread, but I'm giving this script a go and have been persistently running into the following error: Code:
kindMesh (2D/3D) = 3D Input file read correctly Reading of the 'points' file Problem during the 'points' file reading I have attached the python script as run, the associated text file and the associated OpenFOAM case. If anyone has any insights, I'd love to hear from you! Best, Moshe. cylinder.zip testMesh.txt ConvertOpenFoam2SU2.zip |
October 5, 2023, 01:16 |
#42 |
harshawardhank
Rep Power: 13 |
Check points folder created in polymesh directory
October 5, 2023, 01:35 |
#43 |
Moshe Hollander
Rep Power: 8 |
For some reason blockMesh wasn't working there... I tried a different tutorial case where it did work (see attached). There are now in fact 'points' in the PolyMesh folder. I'm still getting the same error. See attached case. implicitAMI.zip |
March 1, 2024, 03:16 |
#44 | |
Forrest WU
Sorry for reply a thread so old, but I'm facing the same problem, so could you give a hint about how to do that? Sincerely, Jianshu Wu |
March 12, 2024, 01:35 |
#45 |
chandrashekhar a patankar
Rep Power: 3 |
you can create mesh in GMESH and export it to su2 format
(just for information) |
October 16, 2024, 18:26 |
#46 | |
TM
Has anyone found a fix for this or understands it well enough to update? Thank you, TM |
