NQ
Rep Power: 0 ![]() |
I am wanting to use an inlet BC at the end of a cylinder that will cause a rotational flow field along the cylindrical wall. Ideally the inlet flow will be tangential to the outer wall all around the cylinder, requiring a BC that has a changing inlet flow vector.
So the question is... Is there a way to specify flow direction based on a reference point/position in cylindrical coordinates? Thanks, Nick P.s. - The only reason I am not too keen on using a rotating frame of reference is that I want to see where the rotational flow field will break down. |
boundary condition, cylindrical coordinates, reference position |
non reflective boundary conditions for incompresible flow | Pascal_doran | OpenFOAM Programming & Development | 16 | August 25, 2015 05:35 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
inlet boundary conditions | newOFuser | OpenFOAM | 1 | January 10, 2013 08:08 |
[Netgen] boundary conditions and mesh exporting | vaina74 | OpenFOAM Meshing & Mesh Conversion | 2 | May 27, 2010 09:38 |
A problem about setting boundary conditions | lyang | Main CFD Forum | 0 | September 19, 1999 18:29 |
