Home > Forums > Software User Forums > SU2
parallel computation
Old   November 18, 2013, 11:16
Default parallel computation
wangjian
jwang1_09 is on a distinguished road
hello,
I encounters a problem when I compute the ONERAM6 in parallel.When I entered "python parallel_computation.py -f inv_ONERAM6.cfg -p 2" in the command line,it appears that sh:mpirun: command not found;sh:mpirun: command not found;sh:merge_solution.py:No such file or directory.I use the Windows platform.
Could you tell me the reason?
Thank you very much.
jwang1_09 is offline   Reply With Quote
Old   November 19, 2013, 18:29
Thomas D. Economon
economon is on a distinguished road
It appears that your machine can't find an MPI installation (you will need a suitable MPI installation, METIS, and python for parallel calculations). Please check out the installation sub-forum for SU2, as several posts discuss getting MPI+Windows to work for SU2.
Hope this helps!
Tom
economon is offline   Reply With Quote
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
Strange post processing resuls for parallel computation of Onera M6 tutorial Akash C SU2 Shape Design 9 August 30, 2013 07:05
Installation issues for parallel computation Akash C SU2 Installation 1 June 21, 2013 06:26
problem in the CFX12.1 parallel computation BalanceChen ANSYS 2 July 7, 2011 11:26
how to parallel computation Jane Siemens 2 April 28, 2004 07:11
