MENDES BORTOLAZZI Andre
Rep Power: 13 ![]() |
Hi developers,
I was trying to understand how the objective function sensitivities w.r.t. the design variables are computed, but I could not understand the meaning of the variable called Sensitivity. If I well understood, it's a scalar product between the flow solution and the adjoint solution at a given node, which is performed by solution_adjoint_mean.cpp and stored in AuxVar. Afterwards, this value is multiplied by the sensitivity of the node's displacement w.r.t. a given design variable in order to compose the sensitivity of the objective function w.r.t. this design variable. Could you explain the meaning of the variable Sensitivity, as well as the mathematical formulation used to compute the final sensitivities of the objective function w.r.t. the design variables? Thanks in advance. Best regards, Andre |
#2 | |
Francisco Palacios
Rep Power: 15 ![]() |
Dear Andre,
The implemented formulation is described in several articles like: http://adl.stanford.edu/papers/AIAA_..._March2012.pdf http://adl.stanford.edu/papers/AIAA-2013-0632.pdf or http://adl.stanford.edu/papers/AIAA-2013-0287.pdf The variable (surface) sensitivity is the derivative of the objective function with respect to perturbations of the geometry (in the normal direction). Best, Francisco Quote:
Tecplot 360 2011 R2 preview with OpenFOAM data loader available for evaluation | scott_rumage | OpenFOAM Post-Processing | 50 | January 23, 2017 02:49 |
Evaluation method for design improvement of bioreactor to prevent biofouling/biofilm | kevinlipps | FLUENT | 0 | March 8, 2012 09:53 |
need some resources for evaluation of Runge Kutta method in CFD | seyedashraf | Main CFD Forum | 0 | June 20, 2011 15:41 |
Specific heat, density evaluation in mixture eqn | CFDtoy | Main CFD Forum | 1 | January 29, 2008 02:08 |
Fatal Error: Face Evaluation Failed | Matthew Campbell | CFX | 7 | October 5, 2001 09:37 |
