How to run SU2 on cluster of computers (How to specify nodes ?) |
May 22, 2014, 14:16 |
#21 | |
Carlos Alexandre Tomigawa Aguni
Rep Power: 12 |
I also received a lot of help when I first started SU2. There's a lot of experts here so don't forget to ask/and answer anytime hehe About your question I don't know what could me done since I'm a newbie just like you haha. But it couldn't be helped considering that you didn't know the exact problem. GL! Carlos. |
March 10, 2016, 04:56 |
#22 |
Amit
Rep Power: 13 |
Hello Guys,
Actually you can run it on a cluster by using --- mpirun -np 30 --hostfile hostfile SU2_CFD filename.cfg (without using python script) Here number of codes are 30 (can be any number). In hostfile (In local directory), you should write nodes for example -- node201 node202 node203 .......... so on This works for me... |
May 16, 2016, 00:00 |
SU2 + GPU in parallel
#23 |
Ernest Yeung
Sean Copeland, I was curious, as this post was almost 3 years ago, and searching here and on Google for "SU2 GPU parallel computing", I only came across this post. What's the status for SU2 on GPU parallel computing and/or any plans? Let us know; I myself am reading up on parallel computing with combustion CFD on parallel threads on GPU in mind.
July 18, 2018, 07:08 |
#24 | |
Samir Shaikh
Rep Power: 8 |
I tried it like first exporting export SU2_MPI_COMMAND="mpirun -np %i %s" and then running parallel_computation.py -f turb_ONERA_M6.cfg -n 10 It works well but my only concern is i'm not getting good scalability. Please correct me if it's wrong |
August 4, 2018, 04:26 |
#25 |
Amit
Rep Power: 13 |
Scalability..... I have not benchmarked any thing but it seems to scale reasonably I feel. Can u share the details i. e. number of cells, cores used, memory etc..
August 7, 2018, 02:36 |
#26 | |
Samir Shaikh
Rep Power: 8 |
I'm running testcase from https://github.com/su2code/su2code.g...bulent_ONERAM6 like "parallel_computation.py -f turb_ONERAM6.cfg -n 4" I'm running it on Intel broadwell nodes with each of 128GB RAM. Thanks again for your help |
September 18, 2018, 11:31 |
#27 | |
Amit
Rep Power: 13 |
Sorry for the late reply. Actually if u have a smaller mesh, it will not scale beyond few cores. I could not give a try to above problem personally but I have given experimental try to couple of cases having mesh size in few 10s of million and they scaled well upto 512 cores or so. |
September 28, 2018, 02:25 |
#28 | |
Samir Shaikh
Rep Power: 8 |
As you mentioned about mesh size, do you know any such tool to generate mesh of larger size which we can use in SU2? |
September 29, 2018, 13:47 |
#29 |
Heather Kline
Rep Power: 14 |
There are a number of different mesh generation options.
Pointwise is a commercial tool that outputs directly into the SU2 format, and there are several options (including some free options) that output to CGNS format, which SU2 can read while using the mesh_format config options. |
February 24, 2020, 14:44 |
#30 |
serg
Rep Power: 11 |
Hello, it is an old topic but I have a similar issue.
When I execute the run with mpiexec command, it works flawlessly. However, when I switch to parallel_computation.py and lets say run the solver on 4 cores, it seems each core does the same computation (4 solutions). I have win 8.1 OS, MS-MPI, python 3.8 (and all packages) are set, the paths are linked. To sum up, I can simulate by using: mpiexec -n 4 SU2_CFD default.cfg (gives 1 solution, ~4x speed up) but not by this one: python parallel_computation.py -f default.cfg -n 4 (gives 4 identical solutions, no speed up) Any help is appreciated. |
Cant run in parallel on two nodes using OpenMPI | CHristofer | Main CFD Forum | 0 | October 26, 2007 10:54 |
Cluster run without master node | Mikhail | CFX | 4 | September 29, 2005 09:58 |
Minimum number of nodes to run CFX in parallel | Rui | CFX | 3 | April 11, 2005 21:46 |
Maximum number of nodes in cluster | Marat Hoshim | Main CFD Forum | 7 | April 9, 2001 18:11 |
Linux Cluster Computing | Mark Rist | Main CFD Forum | 5 | September 10, 2000 06:51 |
