Home > Forums > Software User Forums > SU2
Problem at restart
Old   April 24, 2013, 08:16
Default Problem at restart
Aldo Bonfiglioli
abonfi is on a distinguished road
I am trying to restart an un-steady calculation with version 2.0.3
Despite the fact I am using:
RESTART_SOL= YES
MG_DAMP_RESTRICTION= 0.9
%RESTART_FLOW_FILENAME= restart_flow.dat
RESTART_FLOW_FILENAME= ./restart_flow.dat
RESTART_ADJ_FILENAME= restart_adj.dat
RESTART_LIN_FILENAME= restart_lin.dat
SU2 cannot find the restart file, which i created by re-naming the latest solution file.
Restart flow file name: restart_flow.dat.
There is no flow restart file!!
the full log is enclosed
Aldo
abonfi is offline   Reply With Quote
Old   April 24, 2013, 11:21
Default Sub-directories...
dtucker's Avatar
David Tucker
dtucker is on a distinguished road
Yeah, I tried making sub-directories in the past without much luck. The easiest thing would be to move your restart file up a level so that it is in the same directory as your *.cfg file and *.su2 mesh.
dtucker is offline   Reply With Quote
Old   April 26, 2013, 05:58
Manuel Cellarius
mcell is on a distinguished road
I had the same problem for transient simulations (not steady). It seems that SU2 needs for transient restart simulations also the latest "solution_flow_0000x.dat" file.
Try to rename the latest restart_flow_0000x.dat file to solution_flow_0000x.dat and also copy that one to solution_flow dat. The information in both files is of course the same but in my case that worked.
Hope thats helps
Manuel
mcell is offline   Reply With Quote
Old   May 2, 2013, 14:43
Santiago Padron
Santiago Padron is on a distinguished road
By default when restarting a solution the code will look for solution_flow.dat in the config file
% Restart flow input file
SOLUTION_FLOW_FILENAME= solution_flow.dat
So you can either copy/move the restart_flow.dat to solution_flow.dat or you can modify the configuration file to
SOLUTION_FLOW_FILENAME= restart_flow.dat
For the unsteady case the step at which the code will restart depends on the configuration file option EXT_ITER.
So if you want to restart from solution_flow_00099.dat you will have to specify
% Number of total iterations
EXT_ITER= 100
Santiago
Santiago Padron is offline   Reply With Quote
conduction problem venkataramana OpenFOAM 3 December 1, 2013 08:30
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Backup & Restart problem Sally CFX 4 November 19, 2005 13:44
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
