Home > Forums > Software User Forums > SU2
Scheme
Old   April 1, 2013, 15:18
Default Scheme
malik
malik is on a distinguished road
Can anyone plz confirm me that which type of scheme is used in SU2 to gain second order accuracy . Is it JST?
Thanks in advance
malik is offline   Reply With Quote
Old   April 1, 2013, 17:13
taxalian is on a distinguished road
Send a message via Skype™ to taxalian
Well the integration of convective fluxes is done by using JST and ROE and second order spatial accuracy can be achieved by using these spatial schemes and some others too. For further details see this SU2 publication:
http://su2.stanford.edu/documents/SU2_AIAA_ASM2013.pdf
hope this helps you.
taxalian is offline   Reply With Quote
Old   April 2, 2013, 15:25
Default Objective function
malik
Can anyone plz help me to tell if i am correct in the following description
F(x) = Cd+ rp(CL-CLT)^2
where F(x) is my objective function, Cd is the cost function, (CL-CLT)^2 is the penalty function and rp is the penalty parameter.
I am doing lift constrained drag minimization using adjoint method
Old   April 11, 2013, 14:31
Thomas D. Economon
economon is on a distinguished road
Hi malik,
Just in case you are unaware, we have a python script named shape_optimization.py that will automate shape design using SU2. Within the script, you can specify lift-constrained drag minimization which is already an available option. Please also see the shape optimization options at the bottom of the config_template.cfg file that can be found in the trunk/ directory of the source distribution.
Hope this helps!
Tom
economon is offline   Reply With Quote
how to understand high resolution scheme and high order scheme iilw1314 Main CFD Forum 7 April 12, 2022 13:29
Implementation of QUICK scheme Romuald Skoda Main CFD Forum 11 November 6, 2017 22:20
AUSM scheme ? Central Scheme boling Main CFD Forum 7 January 7, 2016 03:41
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 02:50
extrapolation in MUSCL scheme Chandra Main CFD Forum 6 February 14, 2007 12:21
