Home > Forums > Software User Forums > SU2
Problem with parallel python scripts for dual time stepping test case
Old   March 3, 2013, 15:00
Default Problem with parallel python scripts for dual time stepping test case
sss3700 is on a distinguished road
I've discovered that the parallel_computation.py and merge_solution.py don't quite work for the test cases that use dual time stepping when run in parallel.
I think I've traced the error down to the following sections:
(parallel_computation.py):
# compose function call format and inputs
run_SU2_DDC = os.path.join( SU2_RUN , "SU2_DDC " + Config_DDC_filename )
run_SU2_CFD = os.path.join( SU2_RUN , "SU2_CFD " + Config_CFD_filename )
run_SU2_DDC = "mpirun -np 1 %s" % (run_SU2_DDC)
run_SU2_CFD = "mpirun -np %i %s" % (partitions, run_SU2_CFD)
if unsteady_simulation:
run_merge_solution = "merge_unsteady.py -p %s -f %s -b %s -e %s" % (partitions, Config_CFD_filename, 0, nExtIter)
else:
run_merge_solution = "merge_solution.py -p %s -f %s -o %s" % (partitions, Config_CFD_filename, output)
The merge unsteady doesn't appear to get called for this config file option: 'UNSTEADY_SIMULATION= DUAL_TIME_STEPPING-2ND_ORDER' (I was running the incomp_euler channel flow test case).
sss3700 is offline   Reply With Quote
Old   March 5, 2013, 14:30
Thomas D. Economon
economon is on a distinguished road
There is also one other option that enables the unsteady file writing in the config file. Please set the following option:
WRT_UNSTEADY= YES
With this enabled as well as the dual time stepping option, the files will write in unsteady format with the iteration number appended to the filename (they will be ready for animating directly). I would also recommend writing solutions at every iteration by setting
WRT_SOL_FREQ= 1.
These settings should work well with the python scripts. Hope this helps!
T
economon is offline   Reply With Quote
Case running in serial, but Parallel run gives error atmcfd OpenFOAM Running, Solving & CFD 18 March 26, 2016 13:40
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 08:56
Dual Time Stepping CFD Student Main CFD Forum 20 October 24, 2005 16:57
parallel mode - small problem? co2 FLUENT 2 June 2, 2004 00:47
Time problem in parallel fluent MZB FLUENT 1 May 13, 2003 03:37
