Home > Forums > Software User Forums > SU2
SU2 Residuals
Old   February 8, 2013, 05:52
Default SU2 Residuals
Roberto Pieri
robyTKD is on a distinguished road
Hallo,
I am not able to understand how residuals are calculated.
Are they the sum of all residuals in each cell or the maximum value in the computational domain?
And also, are values saved in the history.csv the log10 of the ratio Res/Res_ref, where Res_ref is a reference value, or simply the log10 of the residuals?
Thank you,
Roberto
robyTKD is offline   Reply With Quote
Old   February 15, 2013, 21:03
Francisco Palacios
fpalacios is on a distinguished road
The residual is the L-2 norm of the residual in the entire domain, and then we compute the log10.
My recommendation is to use tecplot (it is possible to obtain an evaluation copy), the paraview output is unsupported.
Cheers,
Francisco
fpalacios is offline   Reply With Quote
Old   February 17, 2013, 13:44
Roberto Pieri
Thank you Francisco for the reply.
Cheers,
Roberto.
Old   March 15, 2013, 08:19
Default SU2 residuals
malik
malik is on a distinguished road
I am running Inviscid ONERA M6 mesh using the SU2 code. I have run it but it stops after 193 iterations, iwant to increase the number of iterations to to 1500 so plz can you tell what i have to change in cfg file.
Thanks in advance
Regards,
Malik
malik is offline   Reply With Quote
Old   March 15, 2013, 08:36
Samuele Z
samiam1000 is on a distinguished road
Hi Malik,
this is the entry to change the max number of iterations
% Number of total iterations
EXT_ITER= 99999999999
Nevertheless, if it exits after 193 steps it is probably due to a convergence criteria.
Please, post your config file.
samiam1000 is offline   Reply With Quote
Old   March 15, 2013, 17:56
malik
Hi samiam,
there is no error, i need to change convergence criteria
thanks
Old   June 17, 2013, 08:51
Roberto Pieri
I have other questions regarding residuals.
1. Where can I find the strings of the code where residuals are computed?
2. Is it possible to save residuals in the output file? I need to know at least the infinite-norm of residuals.
3. When running SU2_CFD, it prints "Maximum residual: -3.8985e+00, located at point 49659."; I think it is the maximum Res(rho) in the domain, is it right?
Cheers,
Roberto
Old   March 31, 2016, 22:55
OVS
Oliver V
OVS is on a distinguished road
I'm sorry but your answer about the residuals is not clear to me. I get you use the RMS norm on the residuals, but I'm still wondering about the second question from Roberto:
Roberto
in other words, are the calculated residuals relative or absolute?
(My guess is they are absolute since you only mentioned the L-2 norm... but I need to ask).
Thanks,
Oliver
OVS is offline   Reply With Quote
Old   April 5, 2016, 19:46
Tansu
tsevine is on a distinguished road
Cheers,
Roberto
Hi Roberto,
for your 3rd question, as far as i know you are right, it is res(rho).
Regards,
Tansu
tsevine is offline   Reply With Quote
residual
Welcome to the Stanford University Unstructured (SU2) forum! economon SU2 0 January 7, 2013 03:48
New SU2 Forum Opened at CFD Online pete Site News & Announcements 0 January 5, 2013 18:59
judging convergence through residuals MachZero Main CFD Forum 7 December 25, 2012 13:18
Strange residuals of the Density Based Solver Pat84 FLUENT 0 October 22, 2012 16:59
Convergence - scaled vs unscaled residuals HS FLUENT 1 November 7, 2005 06:45
