January 16, 2013, 08:01 |
How to start the tutorial in su2_manual?
feeling
Rep Power: 13 |
I also can't run the tutorial test offered in su2_manual.pdf (page 21).
I don't know how to go forward. My current condition is as following: 1. I download the Source Code named "SU2v2.0" and the "TestCases" 2. I setup the file named "Setup-Windows-x86.exe" in the directory: SU2v2.0\trunk\bin\Windows\32-bit\. The setup path is C:\Program Files\Stanford ADL\SU^2 3. I setup the file named "w_ccompxe_redist_ia32_2013.1.119.msi" in the directory:C:\Program Files\Stanford ADL\SU^2\Intel. 4. Then I open the su2_manual and find the Chapter 3 "Quick Start Tutorial" . I find that: "Again, it is assumed that you have already obtained and compiled the SU2 CFD code (either individually, or as part of the complete SU2 package) for a serial computation." "Move to the directory containing the compiled executable of SU2 CFD (serial version). If you built the code with the build SU2.py script, SU2 CFD can be found in the SU2/SU2Py/directory. Copy the cong le (inv NACA0012.cfg) and the mesh le (mesh NACA0012 inv.su2) to this directory. Run the executable by entering "./SU2 CFD inv NACA0012.cfg" at the command line." I have installed the Microsoft Visual Studio 2008 (containing C++). I don't know what does those mentioned above mean. I don't know where is the command line and how to find the "compiled executable of SU2 CFD(serial version)". I even don't know how to compile the SU2 CFD. In one word, I have little knowledge about C++ compilation. In addition, I find it is better to use console for win7. I don't know what is console. Is it the DOS window(black screen)? I want some help in detail. Last edited by sxhqjfl; January 16, 2013 at 12:04. |
January 18, 2013, 12:09 |
Hi sxhqjfl,
I would suggest you start from scratch. You do not need the source code for windows (and compiling on windows is a pain, as SU2 does not yet have Visual Studio .sln file to compile out of.) Please go to http://su2.stanford.edu/download.html, click "register and download", fill out the form and download the correct version that you want to use (Serial/Parallel and x86/x64). I would suggest a serial version to start out with, because there is a need for more installations with a parallel build. Next install it on your computer (just as you would any Windows installer.) Then go to the installation folder (If you did not change the path, it should be - C:\Program Files (x86)\Stanford ADL\SU2\ if you're running a 64 bit machine, or it should be C:\Program Files\Stanford ADL\SU2\ if running a 32 bit machine. Go to the Intel folder and install the the program in that folder. (w_ccompxe_.......msi) and then if you have downloaded the parallel build you might need to download OpenMPI and/or MPICH2 1.4.1 and install it to get your build to work right. Once you have done these the installation is done. Then follow the quick start tutorial at http://adl.stanford.edu/docs/display...Start+Tutorial To be a real quick start guide to just see it function, download the config and mesh file. Place them in the bin directory of your install (for example, C:\Program Files (x86)\Stanford ADL\SU2\bin\) and then open up command prompt (Start>>All Programs>>Accessories>>Command Prompt) and then change your working directory to the bin folder. For example by: cd "C:\Program Files (x86)\Stanford ADL\SU2\bin\" and then typing the following command (the program followed by the configuration file) SU2_CFD inv_NACA0012.cfg You will have the solution in the bin folder (by default all solution will be in the Tecplot format) Follow instructions in the Quick-Start webpage to change the file format to Paraview and anything lse that you might want to try out. Hope this helps. |
January 18, 2013, 22:10 |
#3 | |
feeling
Rep Power: 13 |
January 18, 2013, 23:41 |
#4 | |
I would suggest you use the binary until you have plans to better the software. Once you get there, I would suggest either running a virtual machine with linux, a dual boot linux machine, or a dedicated linux box. It is so much easier to compile and run on linux than it is on windows, because of all the dependencies that needs to be installed. If you want help installing on a linux machine, you could refer: http://adl.stanford.edu/docs/display...on+from+Source To install Linux, I would suggest using Ubuntu (http://www.ubuntu.com/download/deskt...dows-installer) for dual booting from windows. It automatically takes care of all the boot sectors and everything else. If something goes wrong, log into windows and uninstall linux.... as simple as that. |
January 20, 2013, 21:12 |
#5 | |
feeling
Rep Power: 13 |
January 20, 2013, 23:22 |
#6 | |
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 07:55 |
[ICEM] Question about Shrink Wrap tutorial | zhaohui | ANSYS Meshing & Geometry | 0 | November 23, 2011 22:48 |
on the definition of Start in shell autoignition | mepgzzi | Siemens | 0 | June 18, 2008 11:33 |
Lets start the public domain CFD-Project! | Heinz Wilkening | Main CFD Forum | 3 | March 11, 1999 23:55 |
