Home > Forums > Software User Forums > SU2 > SU2 Shape Design
Non Conformal Tip with GGI interface
Old   October 29, 2024, 08:34
Default Non Conformal Tip with GGI interface
HashBan is on a distinguished road
Dear Forum Members,
I have a turbine blade shroud tip which is non-conformal and want to run an optimization case with discrete adjoint solver. The mesh is generated on ANSYS turbogrid and exported to CGNS using CFX and ICEM. Will it work or is it absolutely necessary to have a conformal tip? I would rather not have a conformal tip because it destroys the mesh.
Regards,
HashBan
HashBan is offline   Reply With Quote
Old   November 5, 2024, 12:22
Josh Kelly
joshkellyjak is on a distinguished road
It is necessary to have a conformal tip, you can enable this in TurboGrid. You need to export CGNS through TurboGrid, not through CFX as exporting via CFX introduces and internal boundary along the tip gap.
joshkellyjak is offline   Reply With Quote
adjointshapeoptimization
Turbomachinery Mass imbalance sheaker CFX 12 September 5, 2019 09:09
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 05:59
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
CFX GGI Interface Error (non-overlapping) surge519 CFX 1 August 3, 2009 19:54
