Home > Forums > Software User Forums > SU2 > SU2 Shape Design
SU2 Constrained shape design of a transonic inviscid wing Tutorial Runtime Error
Old   May 11, 2024, 06:09
Default SU2 Constrained shape design of a transonic inviscid wing Tutorial Runtime Error
zs
ShengZhang is on a distinguished road
Hi everebody,
I'm an absolut beginner in SU2 and currently studying the Design Features of tutorials(Constrained shape design of a transonic turbulent airfoil at a cte. CL) on a virtual machine.
I encountered an error in the final step , the error is
"FileNotFoundError: [Errno 2] No such file or directory: 'config_GEO.cfg_tmp'"
May you help me please ?
Thank's a lot for your help.
ShengZhang
The record the errors are here:
PHP Code:
M6-test3mpirun -n 5 shape_optimization.py -g DISCRETE_ADJOINT -f inv_ONERAM6_adv.cfg
___ _   _ ___                                                      |
__| | | |_  )   Release 8.0.1 "Harrier"                           |
__ \ |_| |/ /                                                      |
___/\___//___|   Aerodynamic Shape Optimization Script             |
SU2 Project Websitehttps://su2code.github.io                        |
The SU2 Project is maintained by the SU2 Foundation                   |
http://su2foundation.org)                                            |
Copyright 2012-2024SU2 Contributors (cfAUTHORS.md)                |
SU2 is free softwareyou can redistribute it and/or                  |
modify it under the terms of the GNU Lesser General Public            |
License as published by the Free Software Foundationeither          |
version 2.1 of the License, or (at your optionany later version.    |
SU2 is distributed in the hope that it will be useful,                |
but WITHOUT ANY WARRANTYwithout even the implied warranty of        |
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSESee the GNU      |
Lesser General Public License for more details.                       |
You should have received a copy of the GNU Lesser General Public      |
License along with SU2. If notsee <http://www.gnu.org/licenses/>.   |
Foundmesh_ONERAM6_inv_FFD.su2
New Project: ./
Sequential Least SQuares Programming (SLSQPparameters:
Number of design variables198 198
Objective function scaling factor: [1.0]
Maximum number of iterations100
Requested accuracy
1e-15
Initial guess
for the independent variable(s): [0.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.0]
Lower and upper bound for each independent variable: [(-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0), (-1000.01000.0)]
Traceback (most recent call last):
File "/usr/local/bin/shape_optimization.py"line 306in <module>
main()
File "/usr/local/bin/shape_optimization.py"line 184in main
    shape_optimization
File "/usr/local/bin/shape_optimization.py"line 282in shape_optimization
    SU2
.opt.SLSQP(projectx0xbitsaccu)
File "/usr/local/bin/SU2/opt/scipy_tools.py"line 128in scipy_slsqp
    outputs
fmin_slsqp(
File "/home/zs/Anaconda/lib/python3.10/site-packages/scipy/optimize/_slsqp_py.py"line 206in fmin_slsqp
    res
_minimize_slsqp(funcx0argsjac=fprimebounds=bounds,
File "/home/zs/Anaconda/lib/python3.10/site-packages/scipy/optimize/_slsqp_py.py"line 329in _minimize_slsqp
    mieq
sum(map(len, [atleast_1d(c['fun'](x, *c['args']))
File "/home/zs/Anaconda/lib/python3.10/site-packages/scipy/optimize/_slsqp_py.py"line 329in <listcomp>
mieq sum(map(len, [atleast_1d(c['fun'](x, *c['args']))
File "/usr/local/bin/SU2/opt/scipy_tools.py"line 498in con_cieq
    cons
project.con_cieq(x)
File "/usr/local/bin/SU2/opt/project.py"line 263in con_cieq
return self._eval(konfigfuncdvs)
File "/usr/local/bin/SU2/opt/project.py"line 211in _eval
    vals
design._eval(func, *args)
File "/usr/local/bin/SU2/eval/design.py"line 151in _eval
    vals
eval_func(*inputs)
File "/usr/local/bin/SU2/eval/design.py"line 541in con_cieq
    func
su2func(this_conconfigstate)
File "/usr/local/bin/SU2/eval/functions.py"line 109in function
geometry(func_nameconfigstate)
File "/usr/local/bin/SU2/eval/functions.py"line 882in geometry
    info
su2run.geometry(config)
File "/usr/local/bin/SU2/run/geometry.py"line 98in geometry
    SU2_GEO
(konfig)
File "/usr/local/bin/SU2/run/interface.py"line 187in GEO
    konfig
.dump(tempname)
File "/usr/local/bin/SU2/io/config.py"line 156in dump
    dump_config
(filenameself)
File "/usr/local/bin/SU2/io/config.py"line 1227in dump_config
    write_config
(filenameconfig)
File "/usr/local/bin/SU2/io/config.py"line 1206in write_config
    os
.remove(temp_filename)
FileNotFoundError: [Errno 2No such file or directory'config_GEO.cfg_tmp'
Requested accuracy
1e-15
Initial guess
Primary job  terminated normallybut 1 process returned
a non
-zero exit code.. Per user-directionthe job has been aborted.
Requested accuracy
1e-15
mpirun detected that one or more processes exited with non-zero statusthus causing
the job to be terminated
The first process to do so was:
Process name: [[21420,1],1]
  Exit
code:    1
ShengZhang is offline   Reply With Quote
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
