December 25, 2023, 02:54 |
Actuator Disk with variable load
Moses
Rep Power: 3 |
I had successfully run single actuator disk with aircraft configuration using "variable load" method. Than I tried to run two actuator disk with the same A/C. The solver does not accept two filenames on "ACTDISK_FILENAME=" line.
Than I built a multizone input, each actuator disk was in different zone and the A/C was in the main zone. Thus the cfg file for each actuator disk had its own "ACTDISK_FILENAME=" line. Running this input the preprocessing was without problems, but after lines "----Begin Solver---" and "Simulation Run using Multizone Driver" the solver stopped with error "BAD TERMINATION ...", "HYD_pmcd_pmpip_control_cmd_cb (proxy/pmip_cb.c:400): assert (!closed) failed" SU2 Release 8.0.0 "Harrier" was used Please Help |
Cfd to ansys thermal to ansys structural interface | ssixr | ANSYS | 17 | July 31, 2015 15:18 |
Valveless Pump Boundary Load Convergence Problems in COMSOL v4.4 | PKawun | COMSOL | 0 | April 23, 2014 09:52 |
OpenFoam-1.6-ext Allwmake compilation error - one last barrier | Pat84 | OpenFOAM Installation | 15 | July 25, 2012 21:49 |
Condensation as an additional variable | Clark Griswold | CFX | 2 | April 21, 2012 07:20 |
Instalation on ubuntu 710 | basilwatson | OpenFOAM Installation | 17 | March 16, 2012 20:16 |
