January 23, 2023, 08:42 |
Shape optimisation not converging
El Nino
Rep Power: 3 |
Hello! I am currently embarking on a specific research on the effects of altering the Mach number on shape optimization for the NACA 0012 airfoil using SU2, based on the "Unconstrained shape design of a transonic inviscid airfoil at a cte. AoA" tutorial. I have not changed anything except from altering the Mach number from 0.8 to 0.88 in the .cfg file. The mesh files and other parameters in the .cfg file are untouched. I then execute the " $ python shape_optimization.py -g CONTINUOUS_ADJOINT -o SLSQP -f inv_NACA0012_basic.cfg" code. My simulations converge till a Mach of 0.88, even though it takes a long time. However, for a Mach of 0.89, the solver does not converge at all. The solver states " Iteration limit reached) and i think the iterations have been set to a limit of 100. Will increasing the iteration limit help? I'm afraid that this step might not aid in convergence and the simulation will just take more time. Any other remedies for this scenario or recommendations on how to approach my research for altering the Mach numbers?
January 24, 2023, 16:42 |
bigfoot
Rep Power: 21 |
Maybe run a CFD only simulation first with SU2_CFD and plot the residuals to see if it converges for the new Mach number. It might indeed be that it takes more iterations to converge, especially when you are restarting from a solution that was obtained for Ma=0.8
January 24, 2023, 22:19 |
El Nino
Rep Power: 3 |
Thank you for your advice! I will give it a try. However, what exactly do you mean by residuals?
January 25, 2023, 10:03 |
bigfoot
Rep Power: 21 |
It is important to understand the basics of CFD before continuing your research.
Besides studying one of the many textbooks on the topic, the youtube channel of CFD101 is a great place to start, here is a lecture on residuals. https://www.youtube.com/watch?v=v9OnNeYH4Ok In SU2, the residuals are reported as RMS values to the screen and to the history file. You can open the history file in e.g. matlab, python or paraview to visualize them and see if all residuals go down. |
convergence, shape design, shape optimization, su2 |
adjointOptimisationFoam: difficulty completing second optimisation cycle | Hugh_ | OpenFOAM Running, Solving & CFD | 3 | August 20, 2024 05:48 |
3D RANS based shape optimisation mesh deformation | nikki_vlk | SU2 Shape Design | 0 | May 30, 2022 05:36 |
Spline generation for Adjoint Based Shape Optimisation | radioactivity | OpenFOAM | 1 | November 1, 2021 01:11 |
Shape Optimisation Parametrisation | Nick Janssens | OpenFOAM Programming & Development | 1 | May 22, 2020 10:47 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
