Home > Forums > Software User Forums > SU2 > SU2 Shape Design
thickness constraint error in unsteady optimization
Old   November 18, 2022, 14:01
Default thickness constraint error in unsteady optimization
zjj
Jianjun Zhou
zjj is on a distinguished road
hello. i found when i deal with the unsteady shape optimization in naca0012 cases, the code can't run correctly with a thickness constraint. The message is shown as below.
Traceback (most recent call last):
File "/usr/local/bin/shape_optimization.py", line 183, in <module>
main()
File "/usr/local/bin/shape_optimization.py", line 92, in main
shape_optimization( options.filename ,
File "/usr/local/bin/shape_optimization.py", line 110, in shape_optimization
config = SU2.io.Config(filename)
File "/usr/local/bin/SU2/io/config.py", line 123, in __init__
tavg_keyGroup = "TAVG_" + historyOutFields[key_inner]["GROUP"]
KeyError: 'AIRFOIL_THICKNESS'
then i found the reason is that the 'if sentence' in below. thickness constraints is not in [historyOutFields]. who can tell me the reason ? thank you in advance!
if self.get("TIME_DOMAIN") == "YES":
objFuncsFields = self.get("OPT_OBJECTIVE")
histFields = self.get("HISTORY_OUTPUT")
diff_objective = self.get("OBJECTIVE_FUNCTION")
constrFuncFields = self.get("OPT_CONSTRAINT")
#OPT_OBJECTIVES
if bool (objFuncsFields):
for key in objFuncsFields:
tavg_keyGroup = "TAVG_" + historyOutFields[key]["GROUP"]
if not tavg_keyGroup in histFields:
histFields.append(tavg_keyGroup)
dtavg_keyGroup = "D_TAVG_" + historyOutFields[key]["GROUP"]
if not dtavg_keyGroup in histFields:
histFields.append(dtavg_keyGroup)
#OPT_CONSTRAINTS
if bool (constrFuncFields):
for key in constrFuncFields:
eqIneqConstrFunc = constrFuncFields.get(key)
for key_inner in eqIneqConstrFunc:
zjj is offline   Reply With Quote
shape optimization, thickness, unsteady flow
shape optimization for RAE2822 with constraint on area Mengmeng SU2 Shape Design 3 September 29, 2019 19:23
what are the scaling factors of Optimization objective and constraint functions ? mechy SU2 Shape Design 4 September 22, 2017 04:23
unsteady rans optimization of NACA64A010 hejiandong SU2 Shape Design 9 April 24, 2014 10:21
Anyone has realized optimization for unsteady flows? hejiandong SU2 Shape Design 3 November 29, 2013 02:44
COMSOL: optimization applied to a laminar flow tdh89 COMSOL 0 April 30, 2012 09:57
