Home > Forums > Software User Forums > SU2 > SU2 Shape Design
Constraning FFD Box movement in +Z direction
Old   July 21, 2022, 15:05
Default Constraning FFD Box movement in +Z direction
Umut Can
Umuteng is on a distinguished road
Hello All,
Is it possible to constrain FFD Box deformation in a specific direction?
I mean, I want to allow the FFD Box to move in the -(negative)Z direction but not in the +(positive)Z direction.
Any help will be appreciated.
Thanks
Umuteng is offline   Reply With Quote
Old   July 25, 2022, 22:00
Wally Maier
wallym is on a distinguished road
Hi Umuteng,
Yes. I always suggest manually creating the DEFINITION_DV field. When you do, you can specify exactly the grid deformation you want to perform -> heres part of an example from SU2's tutorials suite:
DEFINITION_DV= ( 11, 1.0 | UPPER_SIDE, LOWER_SIDE, TIP | WING, 0, 1, 0, 0.0, 0.0, 1.0 );
This FFD design variable with the FFD coordinates of (0,1,0) will only deform in the +Z directions (0.0,0.0,1.0) as defined by the last three arguments.
If you want your variables to be constrained to -Z your arguments would like:
DEFINITION_DV= ( 11, 1.0 | UPPER_SIDE, LOWER_SIDE, TIP | WING, 0, 1, 0, 0.0, 0.0, -1.0 );
Best,
Wally
wallym is offline   Reply With Quote
UDF needed for sinusoidal Piston movement in +-x direction Tanumoybanerjee88 Fluent UDF and Scheme Programming 2 December 4, 2019 03:18
[DesignModeler] simply model, empty box conquer ANSYS Meshing & Geometry 0 March 28, 2014 19:26
Multiple FFD box definition for shape optimization study diwakaranant SU2 1 November 5, 2013 18:46
FFD module for geometry deformation RobinDufour SU2 Shape Design 1 August 19, 2013 13:26
Immersol Simulation of a Heated Box Dong Phoenics 0 March 2, 2006 22:20
