January 28, 2022, 05:57 |
NACA 0012 Optimisation
Abhijith
Rep Power: 5 |
I'm optimizing the symmetric NACA 0012. The constraint is based on thickness.
But when I use SU2_GEO. SU2 is evaluating the thickness of the airfoil as 0. These are my Geometry Evaluation Parameters GEO_MARKER= ( airfoil ) % Geometrical evaluation mode (FUNCTION, GRADIENT) GEO_MODE= FUNCTION Please help me with this. Thanks |
January 31, 2022, 08:18 |
Jan Navratil
Rep Power: 9 |
my guess is, that you must uncomment this: %GEO_DESCRIPTION= AIRFOIL Cheers, Jan |
February 9, 2022, 14:29 |
Abhijith
Rep Power: 5 |
Hi, thanks for the input. Even if uncomment it. The results are the same.
%GEO_DESCRIPTION= AIRFOIL SU2_GEO fails to evaluate the thickness. And I can't apply any constraints under "OPT_CONSTRAINT=" for the optimisation. |
February 10, 2022, 04:32 |
Jan Navratil
Rep Power: 9 |
I tried you input file on my 2D mesh (just airfoil and pressure far field boundaries) and it works. I uncoment thate option what I adviced. But I also commented %MARKER_SYM = (symmetry) I guess your case is 2D as well and there is not symmetry plane. Hope, it will help. Cheers, Jan |
February 10, 2022, 05:15 |
Abhijith
Rep Power: 5 |
@Jan Navratil
Hi, thanks for your reply. I think you are using the full geometry of NACA 0012. My case is symmetric. So, If I uncomment it: %MARKER_SYM = (symmetry) The following error shows up: The configuration file doesn't have any definition for marker symmetry Thanks |
February 10, 2022, 06:01 |
Jan Navratil
Rep Power: 9 |
OK. Maybe this is the cause of your problem. It might be that SU2_GEO is not prepared to calculate thickness of an airfoil modeled as symmetric case.
Jan |
February 10, 2022, 06:09 |
Abhijith
Rep Power: 5 |
@Jan Navratil
Yes, you are right. When using SU2_GEO it fails to calculate AIRFOIL_THICKNESS, AIRFOIL_TOC etc. So I can not constraint the optimisation. |
Data for NACA 0012 | Muntazir | Main CFD Forum | 1 | March 28, 2023 01:59 |
Producing Non-Zero Lift Coefficient for NACA 0012 at AOA=0 | cagesbuild | ANSYS | 1 | January 14, 2020 17:53 |
How to import NACA 0012 Profile in Gridgen | maplepink | Main CFD Forum | 17 | May 7, 2013 13:01 |
Problems with flat plate and NACA 0012 Lift/Force | Harly | FLUENT | 0 | June 18, 2007 10:02 |
NACA 0012 simulation results | Luis | FLUENT | 3 | February 15, 2006 11:42 |
