Pedro Paulo
Rep Power: 5 ![]() |
Are there any Incompressible examples using the Continuous_Adjoint formulation? In the TestCases Repository I found only compressible examples and the case I am trying to run is not working. Regards, Pedro. |
Pedro Gomes
Rep Power: 13 ![]() |
SU2 does not have an incompressible continuous adjoint.
Pedro Paulo
Rep Power: 8 ![]() |
SU2 does have an incompressible continuous adjoint (or at least it used to have one in the past). It is described in
Shape Sensitivity of Free-Surface Interfaces Using a Level Set Methodology. Francisco Palacios, Juan J. Alonso & Antony Jameson. AIAA Paper 2012-3341, 42nd AIAA Fluid Dynamics Conference and Exhibit, New Orleans, LA, June 25-28, 2012. In fact, I even validated it against analytic incompressible adjoint solutions here Lozano, C.; Ponsin, J. Exact Inviscid Drag-Adjoint Solution for Subcritical Flows. AIAA J. 2021, 59, 5369–5373 and here Lozano, C.; Ponsin, J. Explaining the Lack of Mesh Convergence of Inviscid Adjoint Solutions near Solid Walls for Subcritical Flows. Aerospace 2023, 10, 392. https://doi.org/10.3390/aerospace10050392 |
continuous_adjoint, examples/cases, incompressible |
Discrete vs Continuous Adjoint solution variable: Scaling/normalization issue? | asitav | SU2 | 2 | November 21, 2018 19:11 |
Implementation of continuous adjoint SA model | c3k1uI5gzT | OpenFOAM Programming & Development | 1 | August 13, 2018 04:16 |
Shape optimization doesn't converge - Adjoint log file | JPBLourenco | SU2 Shape Design | 0 | December 11, 2017 08:41 |
Continuous adjoint VS finite differences | Haowang | SU2 | 0 | March 26, 2017 03:59 |
Inaccurate gradient results from continuous Adjoint method | Yminjo | SU2 | 1 | January 11, 2014 22:08 |
