Home > Forums > Software User Forums > SU2 > SU2 Shape Design
Gradients for Thrust and Torque coefficients using Finite Differences
Old   July 18, 2021, 12:35
Default Gradients for Thrust and Torque coefficients using Finite Differences
Daaman is on a distinguished road
I want to verify the gradients of thrust and torque coefficients that I have obtained using discrete adjoint, against the finite differences. But, the gradients for thrust and torque are not mentioned in the list of gradients generated on implementing finite differences. In literature, I do see that it was one of the options for Finite Differences - http://adl.stanford.edu/papers/AIAA_...Rotor_2012.pdf. I'm using v 7.1.1. How can I generate the gradients for the thrust and torque coefficients using FD?
Thanks!
Daaman is offline   Reply With Quote
Old   July 19, 2021, 06:46
After comparing the gradients,
Ct (Thrust coefficient) = -CFz (Coefficient of Force-Z)
Cq (Torque coefficient) = -Cmz (Coefficient of Moment-Z)
After going through the literature, I think the above convention is used in the latest version, whereas in the older versions coefficient of Force-X was used for Thrust. But this could be case-dependent based on the axis of rotation.
pimpleDyMFoam with sixDoFRigidBodyMotionCoeffs: External Torque chaz OpenFOAM Running, Solving & CFD 0 May 7, 2017 20:22
Rotor Torque Prediction jason OpenFOAM Running, Solving & CFD 7 August 16, 2016 10:34
Why air’s torque is negative and water’s torque is positive? Jackzm CFX 3 December 16, 2015 17:27
Torque Converter Pump Torque = Engine Torque? Torque_Converter Main CFD Forum 4 November 12, 2012 07:44
