Home > Forums > Software User Forums > SU2 > SU2 Shape Design
FFD_SURFACE_POINTS not created
Old   March 29, 2021, 08:02
Default FFD_SURFACE_POINTS not created
FlyBob91's Avatar
FlyBob91 is on a distinguished road
Hello SU2 users,
I'm trying to set up a 2D FFD box for the design tutorial case regarding the 2D naca profile.
After having set the FFD box, I run the command SU2_DEF, but I noticed in the mesh_out.su2 mesh file that the information regarding the FFD_SURFACE_POINTS is missing
FFD_SURFACE_POINTS=0
Is this the correct procedure for setting the FFD box or I'm missing something? Here attached my .cfg file
I'm working with SU2 v5.0.0
This is the output message of the adjoint log file
----------------------- Preprocessing computations ----------------------
Setting local point connectivity.
Checking the numerical grid orientation of the elements.
Identify edges and vertices.
Computing centers of gravity.
Setting the bound control volume structure.
Storing a mapping from global to local point index.
Reading surface sensitivities at each node from file.
---------- Start gradient evaluation using sensitivity information ----------
Evaluate functional gradient using Finite Differences.
Read the FFD information from mesh file.
There is no FFD box definition. Just in case, check the .su2 file
The input grid doesn't have the entire FFD information!
Press any key to exit...
Thanks for help
FlyBob91 is offline   Reply With Quote
[ICEM] Merge created block resulting in not connected mesh imamwfgf ANSYS Meshing & Geometry 2 October 20, 2013 07:22
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
