Home > Forums > Software User Forums > SU2 > SU2 Shape Design
FFD box for axisymmetrical body part
Old   January 27, 2021, 01:36
Default FFD box for axisymmetrical body part
Umut Can
Umuteng is on a distinguished road
Hello everyone,
I am planning to use SU2 adjoint optimizer for the case in which flow problem is 3D.
However, geometrical shape that I want to optimize is axisymmetric part (nothing but body of revolution). Therefore I need to alter the design points just on a single line and other internal points must deform accordingly so that axisymmetrical part stays axisymmetric.
How can I define such a FFD box?
Thanks
Umuteng is offline   Reply With Quote
Old   January 28, 2021, 07:10
pcg
Pedro Gomes
pcg is on a distinguished road
Cylindrical coordinates FFD.
I know we have the option but I never used it. Look around the testcases folder you might find an example.
pcg is offline   Reply With Quote
Old   February 1, 2021, 15:20
Umut Can
Thanks for your reply. However, I could not find anything related.
any help will be appreciated.
Old   February 2, 2021, 06:29
pcg
Pedro Gomes
Here: https://github.com/su2code/SU2/tree/...ylindrical_ffd
Old   February 6, 2021, 11:59
Umut Can
thanks, this creates ffd box in cylindirical coordinates. However, modified shape in optimization becomes something very far away from body of revolution.
Old   February 6, 2021, 12:58
pcg
Pedro Gomes
It can be done, see attached, but you need to move two points together because the FFD cannot be 0 degree around the circumference (this would probably not work directly with the shape_optimization script).
Old   February 6, 2021, 14:37
Umut Can
I have tried with your files, I attached below mesh obtained at design # 14.
Any idea?
File Type: png Screenshot from 2021-02-06 21-34-56.png (15.6 KB, 26 views)
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF acasas CFD Freelancers 1 January 23, 2015 08:26
[DesignModeler] Creating Fluid Body Inside Solid Part VU_Engineer ANSYS Meshing & Geometry 1 February 24, 2012 22:28
Multi body part and fluctuating residuals tichaona Main CFD Forum 0 February 7, 2012 14:09
[ICEM] Meshing one body part only serezhkin ANSYS Meshing & Geometry 3 June 29, 2010 16:36
application part of laminar newtonian fluid past bluff body swamysrikanth Main CFD Forum 0 December 15, 2009 02:53
