SU2 Shape optimization fails to execute for np > 4 |
September 3, 2020, 16:57 |
Ranjan
Rep Power: 12 |
Hello
I am trying to run the Inviscid ONERA m6 wing optimization tutorial on a local workstation with 8 cores. While executing the shape_optimization.py script in parallel using 4 cores, the optimization runs and converges eventually. However, if I increase the number of cores, the python script results in the exception listed below. I am wondering if others have faced a similar issue ? File "/usr/local/bin/shape_optimization.py", line 183, in <module> main() File "/usr/local/bin/shape_optimization.py", line 98, in main options.nzones ) File "/usr/local/bin/shape_optimization.py", line 159, in shape_optimization SU2.opt.SLSQP(project,x0,xb,its,accu) File "/usr/local/bin/SU2/opt/scipy_tools.py", line 133, in scipy_slsqp epsilon = eps ) File "/usr/local/lib/python2.7/dist-packages/scipy/optimize/slsqp.py", line 208, in fmin_slsqp constraints=cons, **opts) File "/usr/local/lib/python2.7/dist-packages/scipy/optimize/slsqp.py", line 315, in _minimize_slsqp for c in cons['ineq']])) File "/usr/local/bin/SU2/opt/scipy_tools.py", line 457, in con_cieq cons = project.con_cieq(x) File "/usr/local/bin/SU2/opt/project.py", line 257, in con_cieq return self._eval(konfig, func,dvs) File "/usr/local/bin/SU2/opt/project.py", line 206, in _eval vals = design._eval(func,*args) File "/usr/local/bin/SU2/eval/design.py", line 147, in _eval vals = eval_func(*inputs) File "/usr/local/bin/SU2/eval/design.py", line 520, in con_cieq func = su2func(this_con,config,state) File "/usr/local/bin/SU2/eval/functions.py", line 104, in function geometry( func_name, config, state ) File "/usr/local/bin/SU2/eval/functions.py", line 834, in geometry info = su2run.geometry(config) File "/usr/local/bin/SU2/run/geometry.py", line 96, in geometry SU2_GEO(konfig) File "/usr/local/bin/SU2/run/interface.py", line 208, in GEO run_command( the_Command ) File "/usr/local/bin/SU2/run/interface.py", line 292, in run_command raise exception(message) SU2.EvaluationFailure: Path = /media/prateek/NACA0012_Numerical_exp/Wing_Optimization/ONERA/Inviscid/Optimization/Test/DESIGNS/DSN_001/GEOMETRY/, Command = mpirun -n 8 /usr/local/bin/SU2_GEO config_GEO.cfg SU2 process returned error '1' Invalid MIT-MAGIC-COOKIE-1 key-------------------------------------------------------------------------- There are not enough slots available in the system to satisfy the 8 slots that were requested by the application: /usr/local/bin/SU2_GEO Either request fewer slots for your application, or make more slots available for use. A "slot" is the Open MPI term for an allocatable unit where we can launch a process. The number of slots available are defined by the environment in which Open MPI processes are run: 1. Hostfile, via "slots=N" clauses (N defaults to number of processor cores if not provided) 2. The --host command line parameter, via a ":N" suffix on the hostname (N defaults to 1 if not provided) 3. Resource manager (e.g., SLURM, PBS/Torque, LSF, etc.) 4. If none of a hostfile, the --host command line parameter, or an RM is present, Open MPI defaults to the number of processor cores In all the above cases, if you want Open MPI to default to the number of hardware threads instead of the number of processor cores, use the --use-hwthread-cpus option. Alternatively, you can use the --oversubscribe option to ignore the number of available slots when deciding the number of processes to launch. |
September 3, 2020, 19:42 |
Pedro Gomes
Rep Power: 14 |
It seems OpenMPI thinks you have 8 threads and not 8 cores, and so it is protecting you from using more processes than your hardware can efficiently handle.
September 11, 2020, 05:00 |
Ranjan
Rep Power: 12 |
Hi Pedro
You were correct! All this time I thought that my workstation had 8 cores but instead it had only 4 cores and 8 threads. Thank you |
su2 ad openmpi gcc, su2 build, su2 error |
Can SU2 shape optimization function get the minimum value of Lift? | lbfhappy | SU2 Shape Design | 0 | April 5, 2018 01:39 |
regarding su2 shape optimization | bala732 | SU2 Shape Design | 1 | August 29, 2017 12:03 |
Error in shape optimization SU2 v3.2.8 | Fedey90 | SU2 | 4 | February 7, 2016 11:34 |
SU2 Shape optimization questions | AdriC | SU2 Shape Design | 6 | January 27, 2016 05:25 |
SU2 shape optimization initialization method? | gina07 | SU2 Shape Design | 1 | May 2, 2015 17:40 |
