Home > Forums > Software User Forums > SU2 > SU2 Shape Design
Segfault in second DSN iteration
Old   February 6, 2020, 12:02
Default Segfault in second DSN iteration
Jason Trinidad
jtrin is on a distinguished road
Hello!
I'm attempting a shape design with a few geometric constraints using shape_optimization.py. My simulation runs fine until direct CFD is run on my_mesh_deform.su2 in DSN_002. Then I get a segfault right after ParMETIS partitions the graph.
Here's a quick screenshot of the segfault message.
I'm running on 60 cores with (nominally) 384GB of memory available. So I feel I should have more than enough memory available. I also tried running parallel_computation.py using the deformed mesh, and I get the same error.
I noticed that the deformed grid seems very different from the initial grid. It seems like a lot of volume cells have gone missing. Screenshots before deform, and after.
Is it possible that deformation merged some of the grid points? I took a look at the surface and volume deformations and didn't see much out of the ordinary but it might be hard to tell from inspection.
Any ideas as to how I might resolve this? I'm hoping it's just a simple error in my config file. Thanks.
Last edited by jtrin; February 6, 2020 at 16:44. Reason: switched from inline screenshots to links to fix formatting.
jtrin is offline   Reply With Quote
Old   February 7, 2020, 05:57
Tim Albring
talbring is on a distinguished road
Hi Jason,
I just opened a Pull Request that fixes that problem. It was introduced in v7.0.1, so v7.0.0 should work fine ... Next maintenance release (end of this month) will include that fix.
Developer Director @ SU2 Foundation
Get involved:
talbring is offline   Reply With Quote
Old   February 8, 2020, 20:33
Jason Trinidad
Originally Posted by talbring View Post
Hi Jason,
Great, thank you!
Old   February 12, 2020, 13:11
Jason Trinidad
Update: installing v7.0.0 does indeed resolve this issue. Thanks again!
crash, deformation, parmetis
Free surface issues with interDyMFoam for hydroturbine oumnion OpenFOAM Running, Solving & CFD 0 October 6, 2017 15:05
GPU - GeForce GTX Titan Black? frode86 Hardware 11 August 8, 2016 23:36
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
Hardware-Configuration for Fluent HPC-Pack (8x) JohHaas Hardware 9 March 3, 2015 14:25
Parallel runs slower with MTU=9000 than MTU=1500 Javier Larrondo FLUENT 0 October 28, 2007 23:30
