Home > Forums > Software User Forums > SU2 > SU2 Shape Design
Continuous adjoint converge issue in transonic airfoil shape design
Old   December 15, 2019, 10:13
Default Continuous adjoint converge issue in transonic airfoil shape design
zloty001 is on a distinguished road
Hello everyone !
I am dealing with shape design problem and I have got some questions about adjoint parameters, thus I have troubles with converge adjoint calculations.
My direct case was converged well.
  1. What would make adjoint soultion converge and do it quickly ? I have been changing frozen turbulent viscosity, removing sharp edges and changing CFL_REDUCTION_ADJFLOW, LIMIT_ADJFLOW and CFL_REDUCTION_ADJTURB and it didn't bring me good results.
  2. How should I understand CFL_REDUCTION_ADJ parameters? The value I give is reducing CFL like: CFL_NUMBER * CFL_REDUCTION_ADJ = Adjoint CFL number ? Could someone provide me a good guess what factors should I use ? I've tried few combinations in range 0.001 to 1 and even over 1 but none was proper one.
  3. Should I use FROZEN_LIMITER_DISC, FROZEN_VISC_DISC, ADJ_SHARP_LIMITER_COEFF or any of those ADJ parameters? Or should I use only ADJ parameters for flow, turbulence and linear solver ?
To the flow solution I use RANS solver with SA turbulence model, Mach number is 0.85 and Re= 4.6e6.
Direct calculation converged well with CLF number = 50, FGMRES linear solver with LU_SGS preconditioner, entropy fix coefficient = 0.5, second order flow equation and first order turbulence equation.
I attach config file, mesh, screenshots, solutions and restart solution files in link below. I got stuck on this problem for several weeks and would appreciate if someone could help me.
https://github.com/zloty001/CRM_ShapeDesign
Regards,
zloty
zloty001 is offline   Reply With Quote
Discrete vs Continuous Adjoint solution variable: Scaling/normalization issue? asitav SU2 2 November 21, 2018 20:11
High drag for airfoil compared to XFOIL and wind tunnel data Ry10 SU2 15 October 30, 2016 18:27
Fluent Adjoint Solver Convergence Issue? ex10148 FLUENT 2 July 25, 2016 15:41
[DesignModeler] Airfoil generation issue micro11sl ANSYS Meshing & Geometry 1 March 15, 2012 17:09
Question about Continuous Adjoint Method fumiya Main CFD Forum 6 November 1, 2011 11:09
