marco
Rep Power: 7 ![]() |
I have read Thesis_Report_jan_hoogervorst.pdf, he implemented FFD box twist in Su2/grid_movement_structure.cpp back in 2015. In his thesis he has a real nice report on how FFD box deformation works. There he describes that if you use one FFD box to encompass the whole wing (this one box has multiple column/rows of nodes on it's surface) then perturbing one node (or column of nodes in case of adding twist), actually has an effect over the whole surface of the wing (though maybe ever so slightly). He describes that one has to use multiple boxes placed adjacent to each other (say one per wing section) to accurately control the twist of the wing per section. At that time (2015) there was a limit of 10 FFD boxes that SU2 could handle in such a manner. Q1) Is the above mentioned multiple FFD box technique still the way to do this or has the code evolved in the meantime and should I use some other method? Q2) Is this max FFD box limit still in the current code? [edit]: I think I found the answer to this in file SU2/Common/include/option_structure.hpp where MAX_NUMBER_FFD = 15; /*!< \brief Maximum number of FFDBoxes for the FFD. */ is set Thanks, marco Last edited by Marco_Vanderbijl; May 20, 2019 at 12:26. |
Ffd_control_point_2d | feiyi | SU2 | 4 | September 30, 2019 12:42 |
FFD shape deformation for 3D wing not changing the mesh | lwc24 | SU2 Shape Design | 5 | August 1, 2019 15:17 |
FFD box shape won't update using SU2_DEF in SU2 v4.0 | BramT | SU2 | 4 | October 22, 2015 00:25 |
Wing twist optimization using mesh deformation | asthelen | SU2 | 0 | September 29, 2015 21:50 |
Multiple FFD box definition for shape optimization study | diwakaranant | SU2 | 1 | November 5, 2013 17:46 |
