Home > Forums > Software User Forums > SU2 > SU2 Shape Design
FFD_SURFACE_POINTS not getting created
Old   August 17, 2018, 05:53
Default FFD_SURFACE_POINTS not getting created
Suman Vajjala
SumanVajjala is on a distinguished road
We are trying to parameterize the wing surface of a wing-body configuration using FFD technique. However, we are seeing that the output meshfile created by SU2_DEF does not have FFD_SURFACE_POINTS. We do not have this problem with other wing-body configurations for e.g., DLR-F6. Please advise about this issue. Can the FFD technique handle complex geometry features? Is there a limit on the maximum surface points? How do we know the parameterization is succesful?
Thanks & regards
Suman
SumanVajjala is offline   Reply With Quote
ffd, ffd surface points
[ICEM] Merge created block resulting in not connected mesh imamwfgf ANSYS Meshing & Geometry 2 October 20, 2013 07:22
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
