Home > Forums > Software User Forums > SU2 > SU2 Shape Design
inequality constraints incompatible in shape_optimization.py (SLSQP exit mode 4)
Old   April 15, 2018, 15:40
Default inequality constraints incompatible in shape_optimization.py (SLSQP exit mode 4)
tom pratt
tomp1993 is on a distinguished road
I am running a 3D drag reduction optimization using the fixed CL mode as lift constraint (to reduce need for solving lift adjoint every step).
On running the optimization using already converged and validated flow and adjoint restart files, i am returned the message:
  NIT    FC           OBJFUN            GNORM
    1     1     6.646769E-05     2.307356E+21
Inequality constraints incompatible    (Exit mode 4)
            Current function value: 6.64676882e-05
            Iterations: 1
            Function evaluations: 1
            Gradient evaluations: 1
in the job output file.
I am using FFD_CONTROL_POINT variables for the geometry deformation.
i have commented out the opt_constraint option in the configuration file.
Any ideas as to what might be causing this error would be greatly welcomed!
is this happening as a result of not specifying lift as an optimization constraint?
Many thanks,
Tom
tomp1993 is offline   Reply With Quote
Old   April 1, 2020, 14:42
Default Answer
Eduardo Pavoni Gamba
edugmaba is on a distinguished road
Hi, Tom
It's been a while since you have posted it. Do you have any ideia about this problem? I'm also having trouble on this.
I've noticed that my Adjoint Solution didn't converge (Res = 32.68), and I think this may be your problem too. Take a look at the value of your Gnorm, E+21 is not a normal value for that.
Tanks,
Eduardo P. Gamba
edugmaba is offline   Reply With Quote
Old   November 25, 2022, 10:27
Qiulin
qren3 is on a distinguished road
try to reduce the number of DEFINITION_DV
qren3 is offline   Reply With Quote
constraints, fixed cl mode, optimisation, slsqp, su2 adjoint
Incompatible dimensions for operation ruben23 OpenFOAM Running, Solving & CFD 2 June 12, 2015 05:14
[PyFoam] Problems with the new PyFoam release zfaraday OpenFOAM Community Contributions 13 December 9, 2014 19:58
[PyFoam] having problems with pyfoam Installation vitorspadetoventurin OpenFOAM Community Contributions 3 December 2, 2014 08:18
